help! truck just up and died. - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-11-2009, 12:22 AM   #16 (permalink)
Texascadillac42's Avatar
My Photos: (10)
Do the oil filter housing fill test, and check the LPO pressures with a mechanical gauge first.... (you will need a -4 ORS male to 1/8" NPT female adapter, which may not be readily available in your neck of the woods) At least do the oil filter housing fill test....
99 F350 XLT 4x4, Crew Cab, 19.5s, Cummins 12V powered, with a few mods, SBC DD clutch
Texascadillac42 is offline
Old 08-11-2009, 12:24 AM   #17 (permalink)
ALASKA96's Avatar
ok, i will let you know what i find
EARLY '04 F350 EXT. CAB L/B. 5" STRAIGHT PIPE, AFE INTAKE, SCT XCAL 2 WITH ELITE DIESEL AND TUNES. '06 ENGINE W/FULL EGR DELETE, NEW OIL COOLER, STUDS, AND BLACK ONYX GASKETS. CAT ELC.
ALASKA96 is offline
Old 08-11-2009, 12:29 AM   #18 (permalink)
My Photos: (10)
Feel free to PM me if you need anything else....
Old 08-11-2009, 12:33 AM   #19 (permalink)
ALASKA96's Avatar
ok man thanks, sounds like you know these fairly well.
ALASKA96 is offline
Old 08-11-2009, 08:36 AM   #20 (permalink)
ALso look at the HPO rail connectors - mine did the same as yours - blown 'o' ring on the connector. Good Luck !!!
2006 F350 Dually 6.0L Tommy Gate Lo0oking for heated seats !
rcgreg is offline
