help on the vg turbo - Diesel Forum - TheDieselStop.com
Old 10-28-2009, 04:48 PM   #1 (permalink)
Here is the story, on my way to the desert, I was crusing up the mountains towing my toy hauler doing 50mph and boostin around 30 psi. I heard a loud pushhing sound, like I blew off a charge pipe. The boost drop to 15-20 psi. It pushhing sound, like I blew off a charge pipe. The boost drop to 15-20 psi. It was all down hill from there (to my destination ).
I waited till the next morning and checked all the hoses and pipes, no cracks or pipes that came loose. Well I head home and up the hill my boost was between 10-15psi (which took a while to buid up to). Halfway home there was no boost, 10-15psi (which took a while to buid up to). Halfway home there was no boost, a big loss in power, and i could still hear the turbo spoolin.
Next day I took all the charge pipes and hoses off and clean rhem up good and reinstalled them, no difference. I think the vanes need a cleaning, but before reinstalled them, no difference. I think the vanes need a cleaning, but before do that, I would like to hear suggestions
'03 f250 crewcab, longbed, srw, 6.0 powerstroke, 90,000 miles Mods: araid intake system, hogg performance 4" turbo back.
Thanks Robert
StrRacerX is offline
Old 10-28-2009, 05:25 PM   #2 (permalink)
what your describing does sound like a cac tube blew off. is there a tune on the truck? 30 psi is high for a stock truck. the 03 should be in the 24 range. did you check the tube under the air filter? that one usually is the second most common to come off and its the hardest to see. i'm assuming you would have noticed the one on the turbo if it was off. another thing to check is your up pipe connection. i've seen a couple times where those have broken from heat enough to cause low boost in the turbo due to not enough exhaust going through the turbo. it doesn't sound like your vanes are sticking. normally that will cause an overboost and lack of power condition. you would have noticed this without the trailer. hope tyhis helps.
6.0 tech is offline
Old 10-28-2009, 05:36 PM   #3 (permalink)
No tune on the truck. Without the trailer hitched, the truck 25- 27 psi. As soon as I have a heavy load the truck boost goes between 27 - 30 psi. I took off all the charge pipes, silicon hoses and check for cracks or any other signs of a leak... nothing. Put everything back on and truck still not boosting. I do not hear a exhaust leak but I am in the process of removing the turbo and i will check the up pipe for any cracks.
Old 10-28-2009, 11:50 PM   #4 (permalink)
so i pulled the turbo and the vanes are not sticking, but i plan to clean anyways since its off. but as i was checking out the vgtcv, it didnt seem to move as easily as i thought it would, it actually feels stuck, is this normal? any comments or ideas? i included a pic of what i am talking about. please correct me if i am wrong
Old 10-29-2009, 10:14 AM   #5 (permalink)
teamroper60's Avatar
The piece circled in the top pic is the part that makes the vanes move. If it is sticking or does not move freely, that is your problem. It should move smoothly and freely. You need to clean that up and possibly even replace those parts.....
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 10-29-2009, 01:08 PM   #6 (permalink)
i would suggest getting a good carb cleaner and soaking the turbo with it. it looks like you got a lot of rust in there. then take a small buffing wheel with a scotch brite pad on it and make sure the turbo is nice and smooth as well.
6.0 tech is offline
Old 10-30-2009, 05:34 PM   #7 (permalink)
i habe seen the inter cooler pop like a radiator on the side tank making that much boost if you can access a smoke machine that is the best way to check for a blown intercooler it also can be a vgt issue
outlawpony is offline
Old 10-30-2009, 09:50 PM   #8 (permalink)
I had 2 hoses blow off then the last time the gasket around the intercooler blew out. That is very hard to see. Once I had it out it was easy to see the damage, the back right side end cap was separated from the intercooler, but while it was in the truck I could only see a small bit of the orange gasket sticking out
03 XLT F350, CC, Toreador red/silver ,6.0, Auto 4X4, Extang Tonneau. Magnaflow xl turbo back, homemade headlight harness, VR shackles ,harpooned tank, 24" wipers, X-Monitor,FS bypass filter, Energy Suspension sway bar replacement bushings, Sinister coolant filter,HID fogs, scanguage.
alex3 is offline
Old 10-31-2009, 12:32 AM   #9 (permalink)
all my hoses and pipes and intercooler is fine. the truck has no boost. i just cleaned the turbo and vanes. they move easily by hand now. took it for a test drive and still no boost. how can i test the control valve on the turbo? i dont want to spend 340 if i dont have to.
Old 10-31-2009, 07:44 AM   #10 (permalink)
Disconnect both batteries and let the turbo go through a turbo relearn to see if the VGT solenoid is working or not.
Ljutic SS is offline
Old 10-31-2009, 03:31 PM   #11 (permalink)
Batteries were disconnected and removed during the turbo removal. Any other way of testing the vgt control valve? Also, what is the likely hood of the vgtcv piston being stuck?
Old 11-02-2009, 12:22 PM   #12 (permalink)
Does anyone have experience with the vgtcv piston sticking, if so, is there a certain procedure to cleaning it?
Old 11-02-2009, 07:30 PM   #13 (permalink)
can anyone help me out?
Old 11-02-2009, 08:06 PM   #14 (permalink)
I have never seen the actuator piston be stuck but with the amount of rust on your turbo, anything is possible. Frankly, if that has happened, you would probably be better off to simply replace the turbo...
You don't clean the VGT solenoid. You replace it. The replacement will have a screen on it where the oil goes into it. This screen will keep the junk out of the solenoid.
pics
#43
Old 11-03-2009, 03:02 PM   #15 (permalink)
Thanks for reply. Does anyone happen to have a part # for the control valve
