Old 11-07-2009, 12:03 PM   #16 (permalink)
cleaned up and put back together and added a new vgtcv. still no boost. i even did the relearn process.
any other ideas? I do not have the electronical equipment to test the system the dealers around me (san diego, ca) wants to charge 300 for a diagnostic.
anything else i can check out before i drop it off?
StrRacerX is offline
Old 11-08-2009, 04:26 PM   #17 (permalink)
If you brake torque it, does it try to spool or no? Can you hear the turbo doing anything?
Reason I ask, is i've seen cases where you can look at the side tanks of the intercooler and they look fine. Under boost though, a seam will open up, but with no boost, everything looks normal... Matter of fact you couldn't even make the seam open up by tools. You don't realize how much force a few pounds of boost is..
05' F-350 6.0L Diesel Crew Cab Long bed sitting on Brentz Wheels Custom Billet Dually 22's, Kenwood Indash Nav, Sirrrus Sat, HD Radio, Nintendo game Cube, 2 - 7" Tv's in head rests, Dual MTX 10" Subs behind seat, Arp Studs, EGR Block off, Innovative Diesel SCT tuned for Snow Performance Stage III Meth kit, Bully Dog 5" turbo back exhaust, AFE Stage II w/ProGuard 7 Cold Air Intake, Remote Start. 03 Turbo, dam the whistle is Insane! @ 38 PSI
8000K Bi-Xeon H.I.D Headlights, Recon Big Rig, White lighting tailgate light and 3rd LED Brake lights.
05Duallyon22s is offline
Old 11-08-2009, 05:05 PM   #18 (permalink)
what is brake torque?
the turbo sounds like it spools, no boost at all, the boost gauge says 0. the truck feels like it does not have a turbo. anyway i can check the intercooler? and to take the intercooler off, i have to remove the radiator?
Old 11-08-2009, 05:54 PM   #19 (permalink)
Obviously be careful.
But have someone in the truck hold the brake down as hard as possible, get on the gas let it try to spool up like you are going to launch while you are listening for leaks.
Alternate method : How to: make a slightly more baller boost leak detector - evolutionm.net
Without taking the IC off, you can take the hoses off (the motor side not the ic side) Plug up one side.
On the other side
Rig up something (like pvc cap and some connectors) so you can connect an air hose fitting up to and it take it (start of low 1 psi) up to 40 PSI, This will test all your hoses and IC. IF it holds you are good, if not, you know you got a leak..
Sort of like a radiator pressure tester..
