HFCM problem - Diesel Forum - TheDieselStop.com
Old 04-04-2007, 10:30 AM   #1 (permalink)
HFCM problem
While changing my fuel filters the other day I drained the HFCM first. Only problem is usually it fills a Big Gulp cup once. This time it filled it twice and was still draining slowly. I figured there couldn't be much left so I took the filter out. Fuel kept draining the entire time. Filters are changed and truck runs fine. Anyone know what would keep fuel constantly running like this?
beachdiesel is offline
Old 04-04-2007, 10:50 AM   #2 (permalink)
Re: HFCM problem
i think it is luck of the draw with some trucks... i have tried every possible scenario, and only once did my HFCM stop draining. first, make sure that you are pretty close to empty. second, park with the nose of your truck parked slightly downhill. third, pop the fuel cap. fourth, cross your fingers.
i changed mine this past weekend and i drained the HFCM but it would not stop running. replaced the plug, fired up the truck and ran it for a few seconds. popped off the fuel cap - still kept draining. let it sit overnight, and tried again in the morning. HFCM finally stopped draining, so i started to loosen the cap. once the seal was broken, fuel began to drip again. done this drill many times, so had the filter and some paper towels right next to me, replaced the filter, grabbed a garden hose and washed down the driveway...
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System
My truck pictures
double is offline
