i found out... for a ford tech to do it. its going to be 4.5 hours to pull and clean it and another 3.9 to replace it. prolly under $1000 bill before parts if needed... as for a DIY in this, im not touchin it. lol
2003 Ford F350 6.0 Crew Cab/SB/SRW 4x4
Edge Juice Platinum w/ Attitude Controller
Bully Dog RFI Intake
MBRP 5" Turbo Back Straight Pipe Exhaust, Cat Delete
180 Watt Whelen Monster Box Strobe kit. 8 strobes 22.5 watts each.
Rough Country R9000 Shocks
Dick Cepek FC-II Tires
Western Vee Plow
piloting a fire breathing, over boosted, turbo charged, tire smoking, panic inducing, ear drum abusing, spinal adjusting, snow storms nightmare. 2003 f-350 6.0, kinda fast...
I called the local International service center nearby and was told that it was about 4-5 hours of labor as well to pull it at about $99/hr shop rate. Asked if it was worth doing on a 6.0L and he advised that if there is pitting, corrosion, or any other problems they recommend replacing rather than cleaning but won't know usually until it's already off.
He said that he would honestly just replace it with an upgraded one for about $1200-1400 and do the swap in the driveway but said it was an all day job for a do-it-yourselfer. He did not recommend cleaning it if I had not done it before as it is apparently rather easy to mess up the vanes while cleaning. He said that if I have some good manuals, should not be a problem replacing the existing one since it is essentially a part swap, but to check the EGR valve and replace if needed since the same coking that makes the VGT vanes stick will clog the EGR valve.
Not a cheap fix by any means. I'm in the same situation as you right now, with the sticky vanes, but also hear a rush of air but no high pitched whistle, so I'll be checking the backside of one of the hoses to the turbo this evening to ensure there is no leak there which could mask any other issues.
2005 F350 turbo diesel Lariat 4x4 ext cab, short bed, SCT x2, MBRP turbo back, WeatherGuard box, the "beagle hauler".
1965 Factory Five Spyder GT, the 2nd one built out of 39 total. No top, no windows, no radio, no mufflers. Yeah, it's sweet.
I am replacing the EGR valve tomorrow, and will likely try to pull the turbo and HPOP fitting and redesigned oil feeder pipe to the turbo (or save up for the International dealership to do the turbo cleaning and HPOP fitting located under the turbo). Have heard that the oil feeder pipe can get clogged and the EGR valve can be easily damaged when cleaning.
Ordered a remanufactured EGR valve for $70 + shipping and expect a refund of $20 when I send back the core from this reputable guy from eBay. eBay My World - hccs2
Not trying to endorse or advertise, but passing along some info that may save you some loot. I work for the state with a salary that is ridiculously low, so every penny counts for me!
Replaced my egr valve, took less than 10 minutes plus 5 minutes of cleaning out some gunk inside. Will make a new thread. Same symptoms as yours, no codes triggered, seems to run fine now.
