high mileage 6.0s, who's got one?? - Page 4 - Diesel Forum - TheDieselStop.com
Old 07-06-2010, 08:20 PM   #46 (permalink)
Just bought my 03 F350 with 151k on it. I've added 200 miles to it. No maintenance or repair records came with it, so no clue what it's been through.
Looks great inside and out, makes me suspect/hope someone took care of it. Has a 5th wheel. Still learning on what to look for. Gonna take this truck as far as she'll go.
te805 is offline   Reply With Quote
Old 07-07-2010, 02:10 PM   #47 (permalink)
buckshot 2005's Avatar
sounds like a good truck man,I see your from P.C i'm from FWB but i live in crestview.
buckshot 2005 is offline   Reply With Quote
Old 12-19-2012, 10:36 PM   #48 (permalink)
I want to bring this back to the top. I have an '06 with 168k on it. This truck pulls 8000lbs daily, pushes snow all winter and has a vbox spreader in it with at least 2 tons of salt while pushing snow. The repairs have been minimal. 1 injector, turbo VGT ring, IPR, STC fitting, oil rail "o"rings, egr delete when cooler went. Other than that everything was expected from plowing and hauling. 1 set of balljoints, all ujoints, 2 lockout hubs, 1 set of brakes at 120k. Trans at 130k (my fault, broke a cooler line and didnt know it) oh and a window switch. I change my oil every 5k, trans service every 15k, all other fluids every fall. This truck is bone stock. Never had a program on it.
My question is, do you feel that the truck in the warmer areas have a better track record and do you think most people with head gasket issues have programs?
2002PSD crew cab, arizona beige, srw, 7.3 TS chip, 5" exaust, Suncost trans., Volant cold air, 365/65r16 Nitto Terra Graplers, stageI injectors 6" full spring lift w/ ladder bars, H2 turbo, more to come.Sold!!!!! What a mistake. I miss her!!!!
2006 F350 C/C SB Black, SRW, 6.0. Volant CAI, EGR Delete, Moto Metal 951 20" Falkan 305/55R20. Timbrens, and a ton of High Pressure Oil Issues...... Come on International!!!!!!!!!!!!!
prox445 is offline   Reply With Quote
Old 12-19-2012, 10:56 PM   #49 (permalink)
Ty1
Ty1's Avatar
My 04 has 145k and my 06 has 112k. A good friend of mine just sold an 03 with 588k, he has an 07 with 389k, another 07 with 360k, and an 05 with 425k right now. He also has a couple 6.4s with 250-300k along with a couple 800-950k 7.3s. His crew runs a few miles. lol. He did the exact same things with his trucks as I did with mine before he had any problems. Coolant filter, and EGR delete. The only truck with head studs is the 05 which blew the hg's 50k ago.
Ty (Dukey)
I may be the average teenage Farmer/Rancher, but everything done to my trucks I did myself!
2006 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, IPR Research Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 tuner, Air Lift Load Lifter 5,000s w/ On Board Compressor System~~
Early 2004 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008 F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
JUST SOLD>>400,000 MILES!!!~~1999 F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
Ty1 is offline   Reply With Quote
Old 12-20-2012, 10:17 PM   #50 (permalink)
117000 week ago 4 injectors driverside fuel pump,
LILPHIL1 is offline   Reply With Quote
Old 12-23-2012, 02:32 AM   #51 (permalink)
148,500 on my 06. just dealing with a stiction issue. trying REVX and see if that does it....
97 F250 PSD Xcab 4X4 rebuilt trans,precision converter, tugger shift kit, hughes pan,4" bigboar exhaust. 3 gauge pillar, trans,pyro,boost. add a leaf 260,000 miles 06 F250 Xcab 4X4 powerstroke, juice with attitude that is junk. 140,000 miles, 5 " Diamond eye redneck Fartpipe with cat. rolling on 20" grapplers. Gone but not forgotten, 04 Cobra Mustang. Better known as the Corvette Killer. 2.93 pulley, 438/466 HP/TQ.
scootdog is offline   Reply With Quote
Old 12-23-2012, 08:54 AM   #52 (permalink)
cyclone3565's Avatar
Mine has 178k on it and is going strong. If you look at my signature you can see the vast majority of my maintenance. Worth every penny, GREAT TRUCK
Martin - Fort Worth, Texas
2003 F-250 FX-4 --Build Date February 23, 2003 - 180,000 Miles -- Rotella T6 5W40 Synthetic - the only oil with Hot Shots Secrets -- Diamond Mfg. Brushguard - Made In Texas -- 4" Banks Turbo Back Exhaust - strictly straight pipe -- EDGE CS with Attitude and Turbo Down Timer/Pyro (Set on Level 3) -- Upgraded Oil Cooler International 1171962R1 (Dec 2009) -- EGR Block-off Kit (Dec 2009) -- Upgraded HPOP International 2591022C91 (Jan 2011) -- Upgraded Oil Drain Tube Ford 6C3Z-9T515 (Jan 2011) -- New Steering Stablizer (May 2011) -- Upgraded Fuel Pressure Regulator (blue spring) Ford 3C3Z-9T517-AG (June 2011) -- Rousch/Autometer Electronic Fuel Pressure Gauge (July 2011) -- ProForm Fabrication Front Leveling Shackles (July 2011) -- Dfuser Coolant Filter (July 2011) -- New Vacuum Hub Solenoid 7C3Z 9H465A (October 2011) -- New Motorcraft Thermostat RT1169 (November 2011) -- Bilstein 5125 Shocks 33-185569 Front and 33-185552 Rear (December 2011) -- New Sway Bar Links and Bushings Front and Back (December 2011) -- ARP Studs with Ford Motorcraft Head Gasket (December 2011) -- Moog Ball Joints K860T and K80026 (December 2011) -- Rebuilt front axle, repack bearings - Needle bearing No.C6TZ-3123A -- Glow Plug Control Module (November 2012) -- LH Glow Plug Harness and #4 Glow Plug (December 2012) -- Warn Hubs 38826 (December 2012)
cyclone3565 is offline   Reply With Quote
Old 12-23-2012, 09:29 PM   #53 (permalink)
timbo2's Avatar
please report back haw the rev x worked
2005 F350 XL REGULAR CAB 6.0 11 FOOT SERVICE BOX DRW STOCK 212,347 ON THE CLOCK
1997 34.5 FLEETWOOD AVION 5TH WHEEL
2003 F350 XLT CREW CAB 7.3 STOCK DRW 85,000 on the clock
JOHN 3:16
timbo2 is offline   Reply With Quote
Old 12-23-2012, 09:31 PM   #54 (permalink)
timbo2's Avatar
224,000 on the clock it works pretty hard five days a week
JOHN 3:16
Old 12-25-2012, 06:16 AM   #55 (permalink)
07 160k miles...FICM at 100k and the HPOP STC kit at 150k
I am noticing a lot of injector replacements....what makes these go bad?
CH3No2 is offline   Reply With Quote
Old 12-25-2012, 05:25 PM   #56 (permalink)
Stew's Avatar
Excellent thread revisit...
I have an '07 F250 with 130,000 on it. The only issue I had under warranty was an EGR valve replacement. In April (~115,000), I had the EGR Cooler and Oil Cooler replaced as preventative maintenance since I plan on keeping this for a while. In November, had a rough start and rough running issue. Had 3 bad injectors. I went ahead and had all of the injectors replaced as well as the FICM replaced to save on future labor. Hopefully my significant investment in Bulletproof products will pay off. I need to get at least 200,000 out of this truck.
99 F250 SD 7.3L PSD 6spd 4X4 CC SB XL (sold)
04 F350 SD 6.0L PSD AUTO 4X4 CC SB Lariat (sold)
07 F250 SD 6.0L PSD AUTO 4X4 CC SB XLT - 130,000 miles and 3080 hours - Bulletproof EGR Cooler, Oil Cooler and FICM - New injectors at 125,000 miles - Airaid air filter - Otherwise Stock
Stew is offline   Reply With Quote
Old 12-26-2012, 09:41 AM   #57 (permalink)
Ty1
Ty1's Avatar
The injectors in the trucks are double shots instead of the single shots like the 7.3 had. The point is that they send a slight amount of fuel to get it burning then when it's fireing time, it sends the rest while the fuel is pre burning. This idea cleaned the diesel engine up a lot which helped meet epa standards easier. They do wear out a lot faster and are way more sensitive because of this though. They tend to wear out around 150-200k from what I hear where 7.3 injectors don't wear out till around 300-400k. Being way more sensitive also means that cheating oil changes or fuel filter changes will wear them out WAY FASTER. These injectors need as little fuel restriction as possible as well as clean oil. A well maintained motor should last around 200k on injectors. Most people which is the mast majority never even change fuel filters much less oil every 10k which is where you hear all kinds of stories of 100-150k injectors on these trucks. I hope this gives you some insight. This is just the little I've learned over the years.
Ty (Dukey)
Old 12-27-2012, 01:47 AM   #58 (permalink)
There's also an issue with the fuel pump IIRC, not putting out enough pressure. There's a modification(I think it's called the blue spring mod) to raise the fuel pressure. Fuel pressure is very important for these injectors.
Rednecks have more fun!
1992 F350 CC LB 5.8L 5-speed 4.10 L/S. Stock
92F350CC is offline   Reply With Quote
Old 12-27-2012, 04:02 AM   #59 (permalink)
HeavyAssault's Avatar
My Photos: (6)
230K @4800 engine hours. Going strong on the original injectors in my 2006. I can't recall what I've replaced due to "wearing out" but that list is pretty short. I haven't had any of the major stuff others posted. I have been running modded for a long time and only last year did I have studs installed.
FICM electrical health is key to injectors as is oil changes and clean fuel. Good batteries, clean fuel supplied at the right pressure and regular oil changes with OEM filters will do wonders for the injectors.
I didn't go cheap on oil using synthetics since clocking 20k on my truck. Maybe that's part of my good luck.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote
Old 12-27-2012, 06:19 AM   #60 (permalink)
92f2507.3idiprius killer's Avatar
Smile
i have a friend with a f350 with the first year of the 6.0 with around 230,000 injectors have been done twice computer once lift pump once turbo grenaded itself on the highway around 180k on and if u replace the fuel filter cap dnt buy aftermarket we cracked the original by acident and got and aftermarket one and put it on and truck wouldnt start at all the aftermarket caps dnt puch the filter down enough to push down the spring at the bottom and they leak like crazy went and got one from the dealer and got one the truck fired right up.
92f2507.3idiprius killer is offline   Reply With Quote
