High Pressure Oil Leak - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-31-2005, 06:47 AM Thread Starter
I noticed on Ford Dr's site, an article on high pressure oil leaks. One of the early warning signs could be longer crank times. My new 05 6.0 Excursion definetly cranks longer than my last 6.0 did.......sometimes as long as 5 seconds. Question is: What IS a normal crank time......and lets assume no block heater plug used, and we can also assume an ambient temp of say, 50 degreees.
Thanks in advance!
2005 6.0 EX
Nickyj is offline
post #2 of 7 (permalink) Old 12-31-2005, 08:18 AM
fordmastertech's Avatar
Re: High Pressure Oil Leak
Thanks in advance!
[/ QUOTE ] I have noticed the later 6.0s will crank slightly longer and that is normal. If you have the high pressure oil leak most will not start when hot due to the leaking fitting at the HPOP. This is only on the 05s and later engines. I have no idea why they went to that POS quick disconnect fitting on the later engines. It is not a fun job to replace it.
FM
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
post #3 of 7 (permalink) Old 12-31-2005, 12:53 PM
Yep, I had that problem. No start hot, but started cold. replaced the quick disconnect and all is well. It took several days in the shop to fix because they had to order parts.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
SOLD:2011 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Sterling Gray Metallic
SOLD:2005 F350 XLT 4x4 FX4 SRW SC SB 6.0 PSD/TS Med. Wedgewood Blue, Dual Alternators, Tow Command, Bypass Coolant filtration.
djousma is offline
post #4 of 7 (permalink) Old 12-31-2005, 05:22 PM
I'm with you, man! My '05 did the same thing. The crank times gradually got longer and longer until that quick connect fitting finally failed. Boy when it did. However, it was repaired under warranty and I have had no more issues. Mine usually takes longer in cold weather, but, I guess that is the nature of the beast. Hope you have better luck in the future.
2005 F-350 Superduty, 4X4, 6.0 diesel, sc, srw, lariat, B&W Turnover hitch, tow command, red.
2005 Excursion Eddie Bauer, 4X4, 6.0 diesel, 2nd row buckets, all the bells and whistles, Ford 30mm rear anti-sway bar, true blue/arizona beige.
lvsqcsl is offline
post #5 of 7 (permalink) Old 12-31-2005, 11:18 PM
i believe i have the same problem.
i am leaking powersteering fluid, as well as engine oil.
brought it to the dealer, they said it was the oil booster pump (which must be the HPOP). i am waiting for a new one to arrive.
2005 F-250 4door crew cab 6.0 XLT 4x4
Fx4 Torqueshift
snoeproe is offline
post #6 of 7 (permalink) Old 01-02-2006, 02:35 AM
Banned
"Oil booster pump"? This is some pretty unique terminology....
"Be afwaid, be vewy, vewy afwaid." - Elmer Fudd
GrampyJim is offline
post #7 of 7 (permalink) Old 01-03-2006, 06:19 AM
yeah.
i tried using the "search" feture on a few website forums, searching for "booster pump" and couldn't find much.
however, as far as i'm concerned, they can call it whatever they want, just as long as they fix my oil leaks.
Fx4 Torqueshift
snoeproe is offline
