Hmmm...If it ain't broke, don't fix it... Radiator hose/? Leaking.... - Diesel Forum - TheDieselStop.com
Old 07-20-2009, 04:19 PM   #1 (permalink)
First the turbo tube, now this... So much for preventative stuff.
Replaced both the radiator hoses. The lower hose engine side, or near the engine side is leaking coolant. However, seems to sometimes not leak while running then leak while off and hot. Swapped the screw clamp for the spring clamp that is on the lower hose radiator end. Seems a little better, but still leaking. I am going to tighten it some more and see if that helps... What else is down there. Surely I did not blow a gasket just by swapping hoses.
Ideas?
Also, those who have replaced their hoses, did the new upper hose rub on the turbo tube near the radiator side? I don't believe the OEM one was doing that...
Thnks
04 X, 4x4, 6.0, V and Mod B codes, Rear Ford Sway Bar, Poly bushings front and rear on sway bar/end links.
Tony2Co is offline
