Hot lead on Alternator - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 07-09-2011, 05:11 PM Thread Starter
fordnatic68's Avatar
So Im under the hood this afternoon chasin whistles and a valve cover leak and noticed my Hot wire to the alt has melted beyond recognition. It melted about 3 inches of wire and the plastic all around where it bolts to. I removed the plastic cover on back of alt and removed burnt area and everything else looks fine. What would cause somthing like this? I drove it about 250km or 150 miles yesterday.
03 F350 6.0 XLT Lariat Born 12/21/02 Crew cab short box loaded to the nuts
Autometer Guages - Pyro, Boost, Tranny, Oil Temp, Oil pressure,F & R Diff Temp,Voltage, Fuel & HPOP
Custom dash mods to clear up clutter ontop and eliminate blind spot at A pillar
Edge juice w/ attitude ( unlocked)
Banks Intercooler, Hi ram intake n tubes
Twin Optima yellow tops
BD 5" exhaust
Snow Performance Water/Methanol injection w 7 gallon tank (water only)
EGR Delete Kit
Silverline twin 8" slash cut stacks
New stock Ford Hpop
New stock Ford oil cooler (waiting for BD's version of remote cooler filter kit)
Garrett Powermax GT3788VA Turbo
Airaid cold air intake
Zoodad mod
10.5 " Procomp lift (really 8.5 w some mods)
42" good year wranglers w Kevlar sidewalls
5" Bushwacker cut out Flares
Goodhood Dual ram air fiberglass hood from US body
90 F250 Extended cab long box 460 auto
57 Mercury stepside
fordnatic68 is offline
post #2 of 3 (permalink) Old 07-09-2011, 05:45 PM
joshr33's Avatar
If the connection came loose then you would have a higher amp draw thus creating heat.
joshr33 is offline
post #3 of 3 (permalink) Old 07-09-2011, 10:54 PM
dieselmac's Avatar
Could be a few things.
1) Loose connections. Check the alternator and battery connections. Need to be tight and clean
2) Ground problems. Check the battery to frame and engine to frame grounds.
3) Could be a short somewhere
4) Too small wire size. If you have additional load you could be overheating the wire.
5) Bad alternator
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
