How to bleed air from fuel lines? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-16-2009, 09:44 PM Thread Starter
Unhappy How to bleed air from fuel lines?
I have a 2003 F-350 SRW with the 6.0L. I was putting some fuel additives in my tank and the plastic seal jumped in too. A few days later I lost almost all power. i ended up replacing the fuel pump and both fuel filters and the engine is almost back to normal. Once the engine is above 2500-3000 rpm and the turbo kicks in I have all the power but from a dead stop it is very slow to get moving, even when I am in park the engine will not spool as quick as before. I think I may have air in the lines. I have loosend the fuel filter under the hood and then turned the fuel pump on and screwed it down to try to force any air out. It seemed to have much better respone as soon as i fired it up but when I drove it was still sluggish from a stop. I went back to park and then it would not spool up as quick as it should.
What is the best way to blled air from the fuel lines?
Any other ideas?
dbroo052 is offline
post #2 of 4 (permalink) Old 03-16-2009, 10:43 PM
the best way and easiest way is to run it if you can.
Greeser is offline
post #3 of 4 (permalink) Old 03-16-2009, 11:14 PM
Send a message via AIM to blizzardwarrior7
Exactly, it seems that if its still having problems after you've run it a while it might be something else.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
post #4 of 4 (permalink) Old 03-17-2009, 09:21 AM
Check the cap & o-ring on the HFCM.
OMCUSNR is offline
