how to change glow plugs - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 12-11-2011, 06:24 PM Thread Starter
Is it a easy fix to change the glow plugs on a 2004 f-350 xlt diesel, I had just bought the truck and I am trying to replace parts on the trucks so that I know they are new.
2004 F-350 xlt Power Stroke Turbo v-8 6.0
kjkattou is offline
post #2 of 4 (permalink) Old 12-11-2011, 07:07 PM
07PstroKe's Avatar
Send a message via Yahoo to 07PstroKe
Are there any indications that they are bad? Are you having cold or long start issues? How many miles on the truck?
In general, yes replacing glow plugs is one of the easier things to do. Just need to remove a fender skirt and make your self a tool (.020 or .032 wire) to pop off the connectors.
Check out rock auto for OEM motorcraft glow plugs, less the $10 each. If you ARE going to replace them for whatever reason, do not use after market plugs due to swelling.
Larry M.
2007 F-350 6.0 PSD MURDERED
6" Procomp stg II w/37" Toyo M/T's on rockstars
Edge Juice
Stacked 7" straight cut
Pioneer D2 Nav
Sinister Coolant Filtration
Amsoil oil bypass
Blue spring "update"
BD Power hose/clamp kit
CFM+ Intake
6.4 Banjo bolt upgrade
07PstroKe is offline
post #3 of 4 (permalink) Old 12-11-2011, 10:17 PM
dieselmac's Avatar
6.0L glow plugs are unbelievably reliable. They would be way down on my list of things to replace in the name of reliability.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #4 of 4 (permalink) Old 12-12-2011, 04:35 PM
And make sure you get the right one for your engine. They have 2 different lenghts. Depends if yours is a early or late 04.
lenzhotrod is offline
