How clean/inspect EGR valve? - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-11-2005, 08:16 PM   #16 (permalink)
Re: How clean/inspect EGR valve?
What was negative about my post? Simply giving credit where its due for a free plug. Sorry if I rocked the boat with that. I'll be more careful.
If you can read this thank a teacher...thank a soldier it"s in English.
oicu8121 is offline
Old 03-11-2005, 08:22 PM   #17 (permalink)
Guest
Posts: n/a
I got my EGR out with channel-locks [img]/ubbthreads/images/graemlins/eek.gif[/img] and I cleaned it shut with a mig welder!!!!! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
Old 03-11-2005, 08:24 PM   #18 (permalink)
Never said you were a salesman, Doug. I simply noted your plug on a well known fuel additive. Could of been stanadyne, PowerServe...re-read the thread and see who read way too much into what.
oicu8121 is offline
Old 03-11-2005, 08:33 PM   #19 (permalink)
If you've had the EGR plug off, it is reasonable to assume that there is a catalytic converter in your future..... and no big dollar additive will change that.
Did the 7.3's have any problems with catalytic converters plugging?<ul type="square">[*]YES - then a 6.0 w/EGR unplugged will have problems![*]NO - then what makes you beleive that a 6.0 w/o EGR would be any different than a 7.3?[/list][img]/ubbthreads/images/graemlins/shrug.gif[/img]
2008 F-250 Lariat SRW 4x4 CC SWB...
··· 6.4L & Torqshift w/3.73
··· Dark Stone Metallic / Pueblo gold
··· Readylift 3.5" levelling kit
... Toyo MT 315/70/18(bigger than 35-12.50-18)
----- --- BIG$HOW -------<Õ¿Õ¬
Bigshow is offline
Old 03-11-2005, 09:18 PM   #20 (permalink)
F350, I'm sorry. I could have swore that you posted a few months back on Schaeffer's oil and questioned it's ability to be shear stable in the 6.0L.
There were a number of people (me included) that has had good luck with Schaeffer's in our trucks (great wear numbers &amp; shear stability) and someone basically thought that what we were saying was bunk (I mistakingly thought it was you). I goofed up [img]/ubbthreads/images/graemlins/vulnerable.gif[/img]. Anyway, no hard feelings [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2007.5 Chevy 2500 HD (Dark Blue) - LMM Duramax & Allison - C/C S/B 4x4 Z71 - Sirius Sat Radio & iPod (thanks PIE Interface) - Oil Guard Bypass Filtration - 2 Micron Caterpillar Fuel Filtration - EGR Blocker Plate - PCV Reroute - MBRP 4" Turbo Back - EFI Live
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Arkapigdiesel is offline
Old 03-11-2005, 09:55 PM   #21 (permalink)
When you remove the EGR, is it in the open, or closed position? Now if it fails, wouldn't it be a good thing if it failed closed?? Is it closed when you ...ummm...unplug it for....race purposes only? [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
loi1000 is offline
Old 03-11-2005, 10:16 PM   #22 (permalink)
My Photos: (31)
Send a message via AIM to DshiftFF
My 03 7.3 didnt have a cat... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
I see a pattern emerging here
http://www.newenglandturbodieselpowe...rums/index.php
DshiftFF is offline
Old 03-11-2005, 10:26 PM   #23 (permalink)
Just curious, but when you take it out which would be the closed position and which would be open?
2003 F-250 XLT, Crew Cab, SWB, 6.0 TorqShift, ESOF, Limited Slip, Silver,.
Truck Weight Wet, No Payload:
Steer: 4380 lb Drive: 2920 lb Gross: 7300 lb
TRUCK PICS!
Mods:
LINE-X, SteveracerMOD, Autometer Boost-Pyro; A-Pillar mount, MBRP 4" Turbo Back (What's A CAT?) Polished CAC tubes, Custom Heavy Duty Headlight Harness and Silverstar Bulbs, Heavy duty bumpers I built
RockPSD is offline
Old 03-15-2005, 11:04 AM   #24 (permalink)
F350DRW1,
Your point is well taken; I stand corrected and apologize for the misunderstanding. My mind put the wrong accents on the wrong syllables of your post and mistook it for sarcasm. There are some forums where you get slammed for plugging anybody's products.
Thanks again to all who gave feedback on this question.
Doug
SuperDutyDoug is offline
Old 03-15-2005, 12:45 PM   #25 (permalink)
AllOutFirefighter13's Avatar
If you are going to unplug it, then do it with the engine off. There have been other posts who note that when the engine is off, the plug is in the closed position. I think that it has a spring on it to close it when no power is applied, but I'm not sure.
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
