How to fix Speedo? running 38" toyo - Diesel Forum - TheDieselStop.com
Old 05-26-2009, 05:09 PM   #1 (permalink)
I have a 2003 Ford F250 SD, 4x4, 6.0L im running 38/12.50/18's and my speedo is way off, i also think this is affecting my transmission, i have an SCT Live wire and i can adjust the revs per mile on that but i dont think the computer will take it, the revs for these tires are 550rpm, i was wandering if there was a drive gear i could change or something to correct this, Please Help?
Clutchf250 is offline
Old 05-26-2009, 11:14 PM   #2 (permalink)
the intermittent codes that pop up are p0730 and p2701, the tow/haul light flashes on and if i put the truck in neutral and shut it off then start it again, it goes away, i also lose 5th gear when this happens, but if i restart the truck i get 5th back, i have taken the tranny to the shop and had it rebuilt and then again pulled apart and everything tightend after the break in point, they have no idea what could be causing this problem, could it be the bigger tires? please help, thx
Old 05-27-2009, 09:59 AM   #3 (permalink)
dikkstarr's Avatar
Get a Superlift Truspeed and recalibrate it to your tire size, then if you still have that problem its not the tires.
The 6.0l motor has surpassed Hot Chicks as the greatest Money reducing Agent known to Mankind.
2004 F-250 Lariat late build 4X4 CC/LB auto,fully loaded with sunroof, power slider and backup sensors , White with 12" ICON lift, 6 superduty valved bilsteins, flip steering, 38" MTZs on 20x12 chrome Fuel Hostage wheels, stock gears, superlift truspeed, fumoto, high idle mod, large case high amp alternator, floating traction bars, airraid intake with elbow, 4" turbo back, studded, powerslots with hawk pads, billet grill, 55 watt HIDs 6000k heads and fogs, clear corners, 7" Eclipse AVN6620BT NAV w/ back up camera, massive JL stereo 300/4 and 500/1, 2 12s behind back seat, amp research steps, sirius, '08 diff cover, redhead steering box,, coolant filter kit, hush panels and door seal mod, quad pod with boost, EGT, water temp, and fuel pressure gauges
dikkstarr is offline
Old 05-27-2009, 11:57 AM   #4 (permalink)
JW350's Avatar
My Photos: (29)
I've been running 37" tires without speedo correction for 5 years and my trans has not had the problems you describe.
The best you can calibrate for is 35" tires and I believe this needs to be performed by the dealer. Beyond that, the TruSpeed seems to be the only option.
2004 F350, 6.0L TorqShift, SRW, CC, LB, Lariat, 4X4, Built Feb 2004
8" Lift, Fox Shox, 37x13.5x17 Toyo Open Country MT on Weld Evo Velociti XT, 4.88 Gears, MagnaFlow Exhaust, AMP Research PowerStep, Auto Meter Cobalt Gauges (EGT Boost Trans), ScanGaugeII, Firestone Air Bags/Compressor/Tank, BulletProofDiesel EGR Cooler, Valvoline lubricants, Final Charge Global ELC, DieselSite Coolant Filter
JW350 is offline
Old 05-27-2009, 10:25 PM   #5 (permalink)
ok i will give that a shot, thanks
Old 06-28-2009, 03:35 PM   #6 (permalink)
ok so i tried the the tru speed and there is no change, my speedo is correct now, so thats nice, but the light still turns on, and im still getting the same code. Please Help!
Old 06-28-2009, 07:45 PM   #7 (permalink)
dealer or tranny shop to diagnose your issue.
2005 Eddie Bauer X -- all stock.
Wren is offline
Old 06-28-2009, 09:10 PM   #8 (permalink)
P2701 Transmission Friction Element “B” Apply Time
Range/Performance, what is this, is it an easy fix, it cant be a clutch or something i just put new ones in, could it be a soleniod or something
Old 06-29-2009, 05:41 PM   #9 (permalink)
MickC's Avatar
change your gearing to 4.56.......this will get it back to stock, at least the ecu will think it is. More important though, is your braking will be a ton better
MickC is offline
Old 06-30-2009, 06:23 PM   #10 (permalink)
i have reprogrammed the pcm and changed the tire size or axle ratio in programable pararmeters at the dealer many times...works all the time!
dsltek is offline
Old 07-09-2009, 09:32 AM   #11 (permalink)
Ok next step. so i did some reading up on this tranny, turns out its a 3 speed with overdrive for all 3 gears, to get you a 6 speed, but you only use 4th gear when towing. kinda complicated i know, my truck gives me two codes, p0730 (invalid gear ratio) and P2701 (?????b apply time range/ reference?) something like that. which means my over drive is not engaging. My truck shifts super smooth from 1 to 3 to 5. thats all i get. so lets say the clutches are perfect. could it be a sensor and if so where is it and how easy to install? I have been racking my brain on this one. everyone is willing to run checks but there going to get the same code i did and charge me 145 dollars to tell me what i already know. Please help. Thank You.
Old 07-09-2009, 03:26 PM   #12 (permalink)
F250_Lab_Taxi's Avatar
Same here, 37s for over a year now, no speedo correction and none of the problems you have stated.
2004 Ford F-250 Lariat, 6.0L PS
Yamaha 2003 WR250F and 2003 WR450F
2006 Weekend Warrior, FS2300, flipped axle
F250_Lab_Taxi is offline
Old 07-10-2009, 05:28 AM   #13 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
37"s on my 7.3 and 38"s on my 6.0 and none of those problems after a year either.
2006 F250 cc/sb sct, studs egr delete, 100 shot injectors, fass fuel pump, twins, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
2006 Ram 2500 QC/SB Smarty, 5" straight pipe, edge, Leveling kit, 35x13.5" mickey ATZs
2006 International CXT DT466 300 hp 860 tq Diablo powerpuck, 6" straight pipe into 7" single stack
blizzardwarrior7 is offline
