How Long to Register Oil Pressure - Poll - Diesel Forum - TheDieselStop.com
Old 10-08-2006, 10:05 PM   #1 (permalink)
Putting aside the fact that the oil pressure gauge isn't much more than an idiot light (and filters - I use MC), how long are most of you seeing on a cold start (sitting 3 or more hours)? If possible, would appreciate if one of the techs can share what Ford thinks is normal or at least within specs.
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
4x4Mark is offline
Old 10-09-2006, 12:05 AM   #2 (permalink)
Re: How Long to Register Oil Pressure - Poll
I think you may want to think about duplicating this? One with OEM and one with Wix? Or Other?
Peace and Blessings 4-5 sec
Charity, Faith, Hope, and Love!
TimList.net
04/04 F250 XLT 4x4, 6.0, Auto, ESOF, 3.73, CC/SB, TrueBlue & Dark Flint cloth, Born 10/03
Macattak1 is offline
Old 10-09-2006, 08:25 AM   #3 (permalink)
I use stock filters & also have an Oilguard installed. 2 to 3 seconds. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
brassc is offline
Old 10-09-2006, 08:42 AM   #4 (permalink)
jkingrph's Avatar
Use stock filters and Oilguard bypass also.Using Rotella synthetic. Dealer says no problem, engine will not start without oil pressure.
2003 Lariet, LB, CC. Auto, 4x4,3.73 rear end, Oilguard bypass filter, Diesel Site coolant filter, Mag-hytec Transmission pan, Century Royal camper top Turbo diesel life saver.
jkingrph is offline
Old 10-09-2006, 08:47 AM   #5 (permalink)
Right at 2 seconds on level ground after sitting 14 hrs overnight. Ambient temp 50F. Elevation 604 ft above sea level. WIX filter with Motorcraft 15-40.
2004 F-250 Lariat CC, Short Bed, 4x4, 6.0L, TorqShift, FX4, Metallic Green/Arizona Beige, Medium Parchment Leather, Fumoto, B&W Turnover, A.R.E. LSX Tonneau, Built 4/01/04
MoeB is offline
Old 10-09-2006, 09:57 AM   #6 (permalink)
The concern is that the oil pressure used to activate the injectors comes from the high pressure oil pump. The HPOP has a small reserve to start with. The low pressure referenced here feeds that pump, the turbo, and the rest of the motor. So, although it may start fine, is low pressure to the rest of the engine for a few seconds potentially causing other long term problems or a sign of something starting to go?
I'm currently at a solid 5 second delay, which is not the way it was a few months ago.
tks,
Mark
Built: 11/03/03
4x4Mark is offline
Old 10-09-2006, 10:19 AM   #7 (permalink)
OT
OT's Avatar
Could colder temps. today VS 2 mo. ago make a diff? Meaning, could it be oil vis.? 5 sec. does seem long. Potential prob. dont know.
btw..I did poll 2/3 sec.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 10-09-2006, 10:35 AM   #8 (permalink)
I don't think temperature is influencing this to the degree I'm seeing. It was in the 70's here Saturday, 30's this morning. We do see quite a variation in temperatures here this time of year and the delay has been fairly consistent within the 4-5 second range. I tried a fill of Rotella Synthetic last change, and the results were pretty much the same.
Thanks though!
Mark
Built: 11/03/03
4x4Mark is offline
Old 10-09-2006, 04:21 PM   #9 (permalink)
Thanks though!
Mark
If it is always taking 4-5 seconds I would check the oil level before you start the engine to see if there is a drain back issue.
When I do a oil & oil filter change it take 4-5 seconds from then on it is 1-2 seconds for pressure.
I had this issue 2 years ago in which I mention it here before when I was using Wix/NAPA Gold and when the engine sat for more than 24 hrs the oil pressure would take 4-5 seconds again this was 2 years ago.
Since going back to MC filters this has not been a problem,also back then international/navastar stated to me this has been a problem with several and suggested to Ford to R&R the lower oil filter housing check valve assembly this was also in Sept 2004.
"Trade in"
2003 F-250,Lariat loaded and sweet except the 6.0.
Ordered 3/28/07 took delivery 6/7/07
2007 new body GMC Sierra SLT 3500 SRW long bed, Duramax/Allison,Black,loaded and even sweeter and more dependable.
toshiba is offline
Old 10-09-2006, 04:30 PM   #10 (permalink)
Thanks DRC, I am suspecting the drain valve is the culprit - hopefully, the dealership will look beyond "starts fine" and will isolate it.
Mark
Built: 11/03/03
4x4Mark is offline
Old 10-09-2006, 04:36 PM   #11 (permalink)
FWIW - My truck (see sig) has been this way from day 1. Takes anywhere from 3 - 5 to get up to pressure. And it's true pressure because you can hear the engine sound change when the oil gets working through the pieces.
The only time I get 1 - 2 secs is if the truck is warmed up and only sits for a short time.
Maybe the drain valve was shot out of the factory? Maybe it's just the nature of my beast.
04 F-250 6.0 FX4 XLT CrewCab. ESOF. White over Silver. Alum wheels. 3.73. PC78Elite CB w/Wilson 1000. Fumoto quick drain oil valve. Access Cover bed cover. Carry's around two of the greatest little boys in the world!
Engine Born on 12/22/03
Truck Born on 01/04
Truck Purchased 11/4/04
TimsDiesel is offline
Old 10-09-2006, 05:46 PM   #12 (permalink)
Its into the dealer now and the response is "Diesels do that, they take a while to build pressure". Oh well... I asked them to double check the possibility of the drain valve not closing properly. I'll post what I find.
Mark
Built: 11/03/03
4x4Mark is offline
Old 10-09-2006, 09:09 PM   #13 (permalink)
You do realize that the Oil pressure gauge HA! reads normal when the pressure reaches 7 psi(if what I am told is accurate). That guage is nothing more than a glorified idiot light which is either on (normal range) or off (no pressure). At least it is if you are using the OEM guage. If you have an after market "real" guage then ignore everything after "you do realize" .
jbdawson is offline
Old 10-09-2006, 11:00 PM   #14 (permalink)
jbd,
So with that info to go by the one`s that are taking 4-5 seconds to show oil pressure then the engine is running on less than 7 psi for
4-5 seconds.
4X4mark,
After Ford R&R the oil filter lower housing in Sept. 2004 I was still having delayed oil pressure but not as bad,setting longer than 24 hrs with wix/napa oil filters.
On my nexted oil change I switch to MC oil filters from Wal*Mart and I have not had a delayed pressure since,even when setting 2 weeks.
I think I was dealing with both both issues at the time,housing check valve and oil filter.
"Trade in"
toshiba is offline
Old 10-09-2006, 11:54 PM   #15 (permalink)
I do realize how it works - as referenced in the first line of this post. As DRC mentioned, its the change in the time it takes to register - no matter what the threshold value is - that is the concern.
Mark
Built: 11/03/03
4x4Mark is offline
