How long should batteries last? - Diesel Forum - TheDieselStop.com
Old 07-09-2009, 03:10 PM   #1 (permalink)
F250_Lab_Taxi's Avatar
One or both of mine went out at 43K miles and I replaced them. Does that seem about normal? Just wondering...
2004 Ford F-250 Lariat, 6.0L PS
Yamaha 2003 WR250F and 2003 WR450F
2006 Weekend Warrior, FS2300, flipped axle
F250_Lab_Taxi is offline
Old 07-09-2009, 03:17 PM   #2 (permalink)
They should last 4-5 years. I usually replace mine before they quit.
444-4D is offline
Old 07-09-2009, 03:22 PM   #3 (permalink)
Oh ok, mine was just on par then. Thanks! I'm learning as I go...
Old 07-09-2009, 03:25 PM   #4 (permalink)
bugman's Avatar
My Photos: (18)
It depends on where you are located and what you do with your truck. If you live in an area that see 100 degrees quite often then there is a shorter life span for them along with an area that sees -40 for a while over winter. That along with playing the stereo or running the winch or voltage inverter or using the truck as a grocery getter with short trips will also shorten their life span. On my 96 I changed them out at 11 years but could of gotten another couple of years out out them.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 07-09-2009, 06:02 PM   #5 (permalink)
Always change mine around 5 yrs no matter what. I don't like to be stranded.
2005 F250 CCSB FX4 Lariat Lux Pkg, Banks Monster Exhaust, Sinister EGR Delete kit, ARP Studs, Dieselsite Coolant Filter, Edge Insight Gauges, Autometer Phantom II Fuel Pressure Gauge, Blue spring upgrade, 6.4 Fuel Banjo Bolts, Upgraded HPOP fitting, Innovative Diesel SCT X3, Red Head steering box.
champelite210 is offline
Old 07-09-2009, 06:15 PM   #6 (permalink)
mine made it 4 1/2 years, the day they wouldnt start the truck, it was 7* outside and had been that cold for a few days.
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ Dieselsite coolant filter
My Truck
2004/1997 Powerstroke Pics, Ford 9N Tractor,6.0 Bible
dwelch1 is offline
Old 07-09-2009, 09:06 PM   #7 (permalink)
It also depends on when you consider your battery to be "bad"
A battery will start degrading almost immediately. How fast they deteriorate is a function of many things, such as the temperature, how deeply they are discharged, the number of charge/discharge cycles, etc.
It also depends on the quality and/or construction of the battery. Batteries built with thicker plates won't provide as much energy (cranking time) but they will survive a lot more charge/discharge cycles. They will also be more mechanically rugged and not damaged by vibration or rough use.
Typically a battery has much more capacity than you need so you don't notice that the battery is degrading. If nothing unusual happens the degradation continues until one day it just fails to start.
Usually, however, something unusual happens. It gets really cold. Or my favorite: I leave the lights on! Drawing a battery all the way down is hard on them. If the battery was already near the end of its service life it may not recover from a deep discharge.
I would expect three years of service life. Four is doing good. Five is on borrowed time. If I lived where it got below freezing I wouldn't rely on a 5 year old battery.
Rod
rmc50 is offline
Old 07-09-2009, 09:07 PM   #8 (permalink)
I replaced my batteries after 4 years 8 months 103,000 miles. They were still OK but I didn't want to find out hgow long they would last. My wifes Focus battery lasted 7 years.
Ljutic SS is offline
Old 07-09-2009, 09:51 PM   #9 (permalink)
I am gonna hijack this thread to see what make of batteries everyone is using to replace stock. I am just over 5 years 51k and I am going change them soon definitely before winter.
Thanks,
2004/04 F350 Lariat CC LB 4X4 SRW, Dark Toreador/Arizona Beige, 6.0L/Torqshift, 3.73LS, Heated seats, Clearance Lights, TT mirrors, Captian Chairs, Moonroof, ESOF, 12K Receiver
4" MBRP T-409 Cat Back
BlackMax Tonneau
Prodigy Brake Controller
2007 Prowler 3102 BHDS
2000 TERRY EX 27F (Sold)
2001 F250 SC 4X4 5.4L (Sold for '04)
My Pictures.
3gees is offline
Old 07-10-2009, 10:56 AM   #10 (permalink)
I put ford batteries back in. I was getting other service work done anyways.
Old 07-10-2009, 12:55 PM   #11 (permalink)
DizzyD's Avatar
If you have a good local battery shop, stop in and have them test your batteries. A good shop will be able to tell you the "health" of your batteries. It's no guarantee that one wont crap out on you the next day, but highly unlikely if they perform under load.
Also remember that constantly leaving cell phones, GPS and other accessories plugged in after engine shut down beats on your batteries.
2006 F-250 XLT FX4 PSD 6.0, Born in Kentucky 10/05. 4X4 Crew, auto, 3.73, Tow Command, Dark Slate Gray, Oil Guard bypass filtration system and Cyclops no-Start.
*2012 BOSS 302, Blaze Yellow
*1993 F250 4X4, 5.6L farm truck
*2008 Polaris Sportsman 500 HO X2
DizzyD is offline
Old 07-10-2009, 01:23 PM   #12 (permalink)
My 2005 F350 has 67000 miles, both batteries are still checking strong.
J4Rancher is offline
Old 07-11-2009, 11:22 PM   #13 (permalink)
fddriver2's Avatar
If you get 4 or 5 years out of them you have done good...........
I have a philosophy? Who knew. Ok, where's the beer?
2002 F-250 XLT CC SB\HPX\ITP prepump mod\Harpoon\DI 65psi fuel shim\4" SS turbo back Magnaflow\Fumoto\FTVB\Edge Evolution2\Zoodad\2008 Diff cover\V-10 Transmission cooler
fddriver2 is offline
Old 07-12-2009, 10:04 AM   #14 (permalink)
I replace at 4-5, with Motorcraft. They did well in my 97 and are doing well in my 06.
06 F350 4x4 XLT, CC, LB, True Blue, 3.73LS, dash mount Pyro (ESOF knob), with stick, 40K miles, Toyo Open Country MT 275/70/18/E.
97 F350 4x4 XLT, CC, 136k.....SOLD to new owner
GOPDiesel is offline
Old 07-12-2009, 07:31 PM   #15 (permalink)
MickC's Avatar
put thermoil in your batteries and you can get 10-12 years out of them!!!
BatteryDe-Mister.com - Up to 3 times Longer Battery Life! Guaranteed.
MickC is offline
