How long would expect the stock motorcraft batteries to last - Diesel Forum - TheDieselStop.com
Old 09-06-2009, 09:09 PM   #1 (permalink)
How long would expect the stock motorcraft batteries to last?
etherdawg is offline
Old 09-06-2009, 11:16 PM   #2 (permalink)
Got Diesel?'s Avatar
My 97" F-250 7.3 lasted past 10/04 with 150,000 miles (and it was a plow truck!!) when I traded it in on
My 2004 F-350 lasted past 70,000 miles and 3 years old when I sold it
I just replaced the batteries in my 00' plow truck last fall with 110,000 miles
I just replace the battery in my 03' Marauder this summer with 95,000 miles
2011 F350 6.7 cc, sb, lariat -8611lp Blizzard Plow
2000' F-350 Reg cab 4x4 Plow truck- 8611lp Blizzard plow, FTVB, DP Tuner
2001 F-550 Reg cab 6x6 dump truck with 11ft contractors bed- 8611 Blizzard plow
2005 F-350 ex, lb, 4x4 V-10 Blizzard 8611lp plow
1999 f-250 Reg cab 5.4 western 9' pro plow
2003 Mercury Marauder
1989 Mustang Coupe- Drag car 10.96@ 126
Got Diesel? is offline
Old 09-07-2009, 01:31 AM   #3 (permalink)
My original batteries lasted 3 years. This is about average from what I read on the forums.
Mark
bismic is offline
Old 09-07-2009, 01:47 AM   #4 (permalink)
Send a message via AIM to novimustang
I replaced the original batteries on my '03 a few months ago. It started cranking slow, and while the batteries would show a full charge on a Fluke meter, they just weren't putting out the amps anymore. So mine lasted about 7 years and ~120,000mi, which to me is pretty good for a set of batteries. Motorcraft really does make good batteries.
novimustang is offline
Old 09-07-2009, 01:48 AM   #5 (permalink)
Oh yeah and if you are replacing, get the BXT-850s rather than the stock 750s - same price and more cranking amps.
Old 09-07-2009, 07:31 AM   #6 (permalink)
I did the same thing. The BXT-850 is a very good battery. I have owned Ford diesels since 1986 and had very good luck staying with Ford batteries. The worst luck was w/ my current trucks OEM batteries.
The dealership told me that the replacement Ford battery is not the same as the original battery your truck came with. That is why you only have coverage for your original battery under the 3 yr / 36k bumper-to-bumper warranty (does not have an individual warranty).
Maybe they cut corners at the factory in later model years, who knows, but there are quite a few posts on the 05's through 07's lasting just to (or just under) the 3 yr mark.
Mark
bismic is offline
Old 09-07-2009, 08:10 AM   #7 (permalink)
BTW - to get warranty coverage on your batteries you have to drive (or tow) your vehicle to the dealership. They have to have your truck with the bad batteries in it ... AT THEIR SHOP. Definitely a PITA. Definitely replace them in pairs as well.
Also - watch them closely after 2-3 years. You should load test them individually at least twice a year IMO. Low system voltage can cause quite a few operability issues to happen AND can ultimately damage your expensive FICM.
Mark
bismic is offline
Old 09-07-2009, 10:15 AM   #8 (permalink)
69cj's Avatar
Mine lasted 42 months. Replaced with Duralast Gold Tops. 3 year replacement with 8 year prorate. One did go bad after a year and they replaced both at no charge since it was a parallel system. Managers call on that one but made me very happy.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
Old 09-07-2009, 01:38 PM   #9 (permalink)
Send a message via ICQ to clayman Send a message via Skype™ to clayman
Stock batteries in my -03 lasted about 85K miles. Had them replaced with new Motorcraft batteries 8 months ago. Last week one of them was completely dead and was replaced under the 1 year warranty. Just a bad one i guess?
2003 F350 6.0 TURBO DIESEL CREWCAB, EDGE JUICE W ATTITUDE, 4" TURBOBACK, AIRAID STAGE 1.
clayman is offline
Old 09-07-2009, 11:14 PM   #10 (permalink)
Stock batteries in Arizona - Phoenix area? 1 to 2 years MAX. Seldom see batteries last longer than that in our terrible heat.....
ASE Master Tech
Diesel Shop Owner
2005 F350 4x4 Crew Cab 6.0L
Upgraded EGR Cooler
BulletProofDiesel Engine Oil Cooler
http://www.bulletproofdiesel.com
TorqueMasterG is offline
Old 09-08-2009, 01:22 AM   #11 (permalink)
There is no definite answer to this.
It all depends on climate, your use, and a few other things.
Start with 7 years.
If you: clean truck up and listen to radio while you are at take off a year
Do short trips a lot take off a year
Your battery goes dead for some reason and you jump and then
drive it to charge batteries take off a year
You let battery get low on water take off a year
You charge batteries for 24 or more hours if they get any
serious discharge add two years
You live where temps go below 15F in winter take off a year
You live where temps go above 100 consistently in summer
take off a year
I have been a battery fanatic for a long time and I charge my batteries in everything twice per year and I have gotten 8 years out of lots of batteries and 10 years out of some.
This charging deal pays off big time for lawn mowers, motorcycles, boats, and farm tractors. Those machines get longer periods of sitting between use.
Alternators do a great job of maintaining a full charge but do very poorly at bringing a weak battery back to full charge.
Use distilled water, not water from your faucets.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is offline
Old 09-08-2009, 01:30 AM   #12 (permalink)
Start with 7 years.
take off a year
Now that's thinkin' with your dipstick jimmy!!!!
(great post)
Mark
bismic is offline
Old 09-08-2009, 06:56 AM   #13 (permalink)
Agreed, good info
I didn't know about the charging thing, I have cars and equipment that sit regularly and I rely on the charging system to compensate for any drop in power. Will implement this charging style.
Old 09-08-2009, 02:57 PM   #14 (permalink)
Very timely post...I just replaced my motocrafts. One was dead but one was replaced in 07...I put one in the 850 and went to the dealer...the tech told me I should match and buy a pair rather than just one at a time. So i sent back to Autozone and bought a second one.
I can tell they work so much better...starts fast and stronger.
My 06 has 60K on the clock.
2006 F250 King Ranch PSD, ARP Head Studs, EGR Delete, 4" Turbo Back no cat
Rollingrock is offline
Old 09-08-2009, 05:22 PM   #15 (permalink)
lincster's Avatar
My Photos: (22)
Another Phoenix guy here. 2 years and 30,000 miles is what mine lasted.
2006 F350 4X4 Dually, Tow Boss, Crew Cab, Lariat... Inyati Spray In Bedliner, Autometer Z Series Gauges towing a 2006 LE3905 Weekend Warrior
On order: 2012 F350 4X4 Dually, Oxford White, Black Leather, Ultimate Lariat Package
lincster is offline
