One at 2K when I lost 4 or 5 injectors at the same time......fried the turbo when desiel filled and overflowed the oil! Funny, the truck didn't seem to want to run...for some reason????
_________________________________
The above information may be speculative, based on misinformation, contain inaccurate data or could be entirely tongue-in-cheek, depending on how litigious the reader may be, how much liquor I've consumed, the degree of stupidity and/or gullibility exhibited by any poster/reader I may respond to. Your mileage may vary. All civil rights reserved. LET'SROLL! 03 F-350 6.0 PSD, XLT, 4x4, CC, auto, skull billet grill, nurf bars, 4" lift, BFG 37x12.50R17, 8.5" Weld Wheels, tonue cover, keyless entry, supersonic alarm, painted bumpers, rear sensing, privacy glass, rear slide window, power everything, drive shaft red, 3.73 gears, camper/tow, block heater, Pro-Guard 7 intake, DPPI exhaust-no cat, Built: 1-13-03 Bought:4-11-03 Flash-06E17 7-5-06 [image] http://photos.thedieselstop.com/show...Truck_350_side [image]
Updated has a relief cut into the housing to prevent the vanes from seizing/rusting to the housing. The up dated turbo part number is 3C3Z-6K683-BARM. Old turbo number ends in AARM.
None, on either, 48,500 on the 05 and 23,300 on the 06!!
2001 White Lariat 7.3 Auto CC LB 4X4 -- Mods -- K&N Drop in, DP Tuner, 6.0 IC mod, 4" Magnaflow Exhaust, BTS Tranny, 3 gauge A piller pod. Kennesaw Mountain Accessories Rear and Front “Wincher” Bumper, Warn 16.5Ti Winch, Suspension: Tuff Country 2" front and 3" rear, Toyo MTs 305s on 10s, 310,000 miles!!
05 White XL 6.0 Reg Cab 4X4 140,500 miles!! (That has never seen the inside of a Garage)
06 White 6.0 CC Lariat 4X4 Auto LB: Kennesaw Mountain Accessories Front “Wincher” Bumper, Warn 16.5Ti Winch, Fabtech 8" lift, 35 Toyo M/Ts 125,651 miles!!
---07 Shelby GT500--- Performance White Vert-- Mods-- JLT Intake, 2.6" upper & 10% IW Lower Pulleys, AFCO Duel Pass Heat Ext., American Racing Long Tube Headders, Full 3" Magnaflow Exhaust, Evolution Stage 4 Tune, BMR Carbon Fiber Drive Shaft, Steeda UCA & LCAs Currie 9" 1:3:75s True-Trac locker, Proglass Cold Air Hood, 36,500 miles---11.491 1/4 mile! 592RWHP
36K none.
After a few miles remove the intake at the turbo and see how much oil residue is caked on the vains.
Last July,05 with 23K I was R&R the turbo-intercooler tube and hoses with new one`s and found approx. 4 oz of oil in the tube when removing it.
After that fix I then removed the intake to see if oil was also in the intake and turbo and found the vains caked in oil residue.
I clean it up everything as much as I could and then did a CV mod.
I had my truck in for a #4 injector on May 19,06 and when the tech had the intake off everything was still clean.
And no more oil soaked turbo-intercooler hoses or blowing off of the blue hoses.
My thoughts are some engines might have a little more blow-by than others which those could be more of a problem.
My Ford tech thinks its just bad turbos(if that is the case then the turbo mfg production is at about a 30% failure rate),he also says it could very well be oil caking up in the turbo causing failures.
2006 F250,CC SWB,Lariat,6.0PSD,4X4,FX4,moonroof, chrome package, tow command, and all the bells and whistles.
2003 Excursion Limited Ultimate, 6.0 4WD, DVD, Quad Seating, Mineral Gray Metallic, build date 5/03
2001 F250, CC,SWB LARIAT,7.3PSD,4X4,OFFROAD PKG, RED & BLACK, AUTO,ESOF,6CD-RADIO,ELECTRONIC BACKUP SENSORS,K&N FILTER. Sold this ride.
2000 F250, SC, SWB Lariat, 7.3PSD, 4X4 Offroad pkg,traded for 2001 CC
The factory original was replaced at 17,000 miles.
[img]/ubbthreads/images/graemlins/eek.gif[/img]David
2004 F350 Lariat, CC, LWB, 4x4, Dually, 6.0L w/ TorqShift, 4.10 LS, Dark Charcoal Gray, Permatech sprayed liner, A-pillar pod with 3 Isspro gauges, windshield-mount gauge pod with 3 more Isspro gauges, AIC, Jason cap, and PIAA fog lamps, mounted as aux. back-up lights. Billet badges. Alpine radio, a bunch of JL Audio and Sirius stuff.
Thanks red03..
Now we know what 'updated' means.
BTW , thefirst turbo was replaced after many trips back to the dealer,and I assume their last resort.
Worked for a while ,6 months or so then back to the same thing.
Next replacement was easy: "it fixed it last time, we'll just put in another". It's not my call.
Same this time. No fighting.
This is a work truck, all I want is for it to work.
Great dealer by the way.
Lets see....
At 92K I swapped the stocker for a modifeid unit.
I blew that up after 4K miles spinning it to 55 PSI. LOL
I put an identicle one on it that's going just fine now...111K on the clock now
About to replace that one with a Gerrett GT42R non-vgt unit in my quest for 600 rwhp on #2 only.
So...under warranty....zero
Just for fun ....2 going on 3.
Best truck I've ever had...and it trapped 110.35 mph last Friday.
...coming soon... 2004 Twin Turbo 5.9 F250 Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
