6.0L Power Stroke Engine and DrivetrainDiscussion of the 6.0L Power Stroke diesel engine and drivetrain in the 2003-Up Super-Duties and Excursions. No gas engine discussion allowed except on transmissions and drivetrain that pertain to all models. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
2003 F 350 Crew Lariat 6.0L psd
4" magnaflo cat(less)back exhaust
slightly massaged airbox
4" lift
rollin' 33's for now...
high idle mod(with lighted switch installed where the power pedal switch would go)
Never had a vehicle that required so much learnin'
I paid $385 for studs. (R&E Racing on Ebay)
$134.00 a side for head gasket kits (comes with bolts you don't need) Wabash Truck Center
$300 for new oil cooler on ebay.
$200 for new egrcooler on ebay.
$100 for an "EGR Cooler modification kit"
$1100 for machine shop, heads milled, valves cleaned and ground, new guides, new valve seats, etc.
Probably throw in another $100 for miscellaneous gaskets, $60 for anti-freeze, and $150 for coolant filter kit and filters.
I did the work myself...new glowplugs, new belt, new water pump, new hoses, new thermostat, new fuel injector wiring harness, and glow plug wiring harness. The wiring harnesses were damaged, everything else was just preventive while it was all apart. I also cleaned the turbo.
2004 F-250 King Ranch CrewCab ShortBed 6.0L
I paid $550.00 for the bolts and about $220.00 for labor since the dealer already had ny motor pulled from the truck to take care of the bed plate (oil leak). They did not install new head gaskets just pulled on bolt at a time and installed the ARP studs.
2006 F-350 Crewcab, Amarillo, pkg. 7" DR 4link kift, 355/60/20 Toyo AT, American Racing 20x10 Mojave 4.5 backspacing
2003 E-350 Cutaway single, Sparton utility box, Eagle wheels, tow mirrors
Looks like I'm going to need new head gaskets and I will need head studs. My truck doesn't like 32+ psi. How much did you pay for this upgrade?
I paid around 400 for my studs. I want to say around $1200 for gaskets, I had to buy heads so i spent around $7000 and yes im a little bitter about it.
WOW! $7000 is almost a brand new motor. This was my fear when I bought a 6.0. I would end up spending as much to repair as to replace with a new motor. I'm praying I don't need heads because as things are right now, my rigger is sitting until this economy picks up. Really unfortunate too.
I'll repost with updates. I'm saving for parts now. Then labor. Need studs, gaskets and an oil cooler.
2005 250SC FX4 6.0L 3.73's, '03 Turbo "Whistler", '07 turbo drain tube, AFE PRO Stage 3, Edge Insight; MBRP Turbo back cool duals, cat delete, SCT X3 Programmer with my custom tune, CFM Inlet, egr cooler delete, billet egr delete, coolant filter, Boss 8' Pro Poly, Wheelen hide-a-way strobes, Sho-me LED's.
A new not rebuilt motor is a little more then 2 times the cost of $7,000 heads. About $15K and some change.
