How Often To Replace Fuel Filters? - Diesel Forum - TheDieselStop.com
Old 09-11-2007, 04:28 PM   #1 (permalink)
How often does Ford recommend changing the fuel filters on the 6.0? How often do you recommend doing it? I've been doing every 10k and I'm not sure if this is to often. Also, I've been getting my filters from http://www.filter1.com. Is there anyone cheaper who also gives good service?
2004 F350 / Crew Cab / Short Bed / Diesel / Lariat / Single Rear Wheels
Picture of my rig with my gooseneck dropping off a shipping container at a customer's house:
http://farm2.static.flickr.com/1152/...e894765e_b.jpg
Allagash is offline   Reply With Quote
Old 09-11-2007, 04:39 PM   #2 (permalink)
FINE69's Avatar
Re: How Often To Replace Fuel Filters?
I'm not sure what the manual says. I change mine every third oil change (every 9000 miles).
2009 F350 CCLB Larry-at, 6.4, all the toys....
http://community.webshots.com/user/FineFord
FINE69 is offline   Reply With Quote
Old 09-11-2007, 05:25 PM   #3 (permalink)
ford say 15k miles, i would recomend every 10k miles. too bad it is a royal pita to do them. im due, and want nothing to do with it...
2006 f-250 q-cab, lariat, 4wd medium wedgewood blue and arizona baige, bfg 305's
55k miles
1982 jeep scrambler
2001 bmw 525i 90k miles
ncmallard78 is offline   Reply With Quote
Old 09-11-2007, 06:24 PM   #4 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fine69</div><div class="ubbcode-body">I'm not sure what the manual says. I change mine every third oil change (every 9000 miles). </div></div>
Why are you changing oil every 3k?
I change my fuel filter every other oil change at 15k. We have pretty good fuel here. I have yet to see any WIF. Delo 400 at 7.5k intervals, no romps, surges and it fires right up, runs smooth, with plenty of power.
OMCUSNR is offline   Reply With Quote
Old 09-11-2007, 07:36 PM   #5 (permalink)
OT
OT's Avatar
How do your f.f. look at 10K mi.? Ex: Dirty/can't see white filter media + black speck's or gunk floating in fuel. Or media partially dark colored or media just barely dark & so forth. You probably get the idea.
Book says (as mentioned) 15K. However you might need to change sooner or maybe later. Meaning you could get more than 15K mi. on a set. Just don't forget..dirty fuel can wipe out a new set of f.f. real quick. I know, been there/done that. Carry spare set.JMO!
btw..ITEC (old name/International) 4.5L f.f. are same used in 6L.(I use them) Meaning don't ask for 6L PSD f.f. [img]/forums/images/%%GRAEMLIN_URL%%/laugh.gif[/img]
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline   Reply With Quote
Old 09-11-2007, 07:45 PM   #6 (permalink)
FINE69's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: OMCUSNR_RET</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Fine69</div><div class="ubbcode-body">I'm not sure what the manual says. I change mine every third oil change (every 9000 miles). </div></div>
I change my fuel filter every other oil change at 15k. We have pretty good fuel here. I have yet to see any WIF. Delo 400 at 7.5k intervals, no romps, surges and it fires right up, runs smooth, with plenty of power. </div></div>
I change every 3000 more because of time than miles. I don't use my truck everyday, so its easier to just change it every 3000.
Old 09-11-2007, 08:37 PM   #7 (permalink)
fuel filters are much cheaper than injectors... that why i do it every 10k miles.
55k miles
1982 jeep scrambler
Old 09-11-2007, 09:06 PM   #8 (permalink)
Texrob1's Avatar
Send a message via Yahoo to Texrob1
I do mine at 15K also,oil every 5K.
2005 F250 XLT wedgewood blue 4x4 C/C SWB,6.0L PSD, Auto.(Member of 05 STC Failure Club ) 2006 Expedition Eddie Bauer,5.4L (Wife's) NRA Life Member. TSRA Life member.
Texrob1 is offline   Reply With Quote
Old 09-11-2007, 09:23 PM   #9 (permalink)
caissiel's Avatar
my truck fuel filter has been serviced entirely by the dealer at 15K miles and the oil changed at 7.5K just like the book says. with ULSD fuel it is even better on the oil and fuel filter
2005 Ford SD F250, 6.0L Diesel, Extended Cab, 4 x 4, 6 Speed, 2 Alternators, 2008 Mirrors, 10,000GVW, Max Energy by Hypertech, ScangaugeII for available 60 XGauges and MPG. 20MPG and 12.6 MPG Towing a 15500Lbs 38ft RV 5th Wheel.
caissiel is offline   Reply With Quote
Old 09-12-2007, 05:21 PM   #10 (permalink)
I replace mine every 10k. I purchase my filters at http://www.dieselfiltersonline.com . Very cheap and OEM filters. No problems at all with them.
afdbigdaddy is offline   Reply With Quote
Old 09-13-2007, 10:04 AM   #11 (permalink)
lincster's Avatar
My Photos: (24)
Helped my next door neighbor do his change last weekend. Was his first time........ at 38,000 miles. [img]/forums/images/%%GRAEMLIN_URL%%/shocked.gif[/img]
He said he was still getting 17mpg. He has an 06 F250.
I told him he was nuts.
2012 F350 4X4 Dually, Crew Cab, Ultimate Lariat Package, Oxford White, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
lincster is offline   Reply With Quote
Old 09-13-2007, 12:49 PM   #12 (permalink)
I accidentally missed a change & went just about 30k. I was fortunate - we have pretty good fuel around here, and the old filters were not badly discolored & had no WIF when I drained it. No loss of economy either.
I won't do it again, but I lucked out last time.
Old 09-13-2007, 09:37 PM   #13 (permalink)
I'm on my 3rd set including originals at 28k and I would say I am wasting money because the ones I take out look as good as the new ones I put in.I guess I should be happy but I almost would like to see some scum on them.I would say that I buy from a very high volume fuel dealer & use fuel additives 100% of the time(power service)I justify changing them so often because I caught a deal on them from international.$90.00 for 3 sets and dealer wanted $100.00+ labor for 1 set.I think I could go 20k on a set but it will never happen!!
2005 F350 Reg Cab 4X4 SRW XLT 6.0 SOLD 1/31/08
2008 F250 SUPERCAB 4X4 SWB SOLD 10/23/2011
2011 F250 CREWCAB SWB 4X4 6.7/AUTO XLT
dmags is offline   Reply With Quote
