I just replaced my EBP sensor....what's all that black crap? - Diesel Forum - TheDieselStop.com
Old 03-11-2005, 11:42 AM   #1 (permalink)
Well, I've had my EBP sensor replaced once and it cured my surging at idle. It was starting to do the same thing so I replaced it myself this time.
The line that leads to the EBP sensor has A LOT of black soot looking stuff in the line that looks to be accumulating. Is this normal? In order to avoid a moderator deleting this thread I will try and word this next sentence delicately.....I have an extra EGR that stays plugged on top of my engine, but the EGR that is actually in the engine is closed up (I have it like this because I only use my truck for off road purposes). Would the EGR in my engine that stays closed have any effect on the soot in the line leading to the EBP sensor?
2007.5 Chevy 2500 HD (Dark Blue) - LMM Duramax & Allison - C/C S/B 4x4 Z71 - Sirius Sat Radio & iPod (thanks PIE Interface) - Oil Guard Bypass Filtration - 2 Micron Caterpillar Fuel Filtration - EGR Blocker Plate - PCV Reroute - MBRP 4" Turbo Back - EFI Live
Never argue with an idiot. They will bring you down to their level and beat you with experience.
Arkapigdiesel is offline
Old 03-11-2005, 12:51 PM   #2 (permalink)
Re: I just replaced my EBP sensor....what's all that black crap?
Answer to the Q is no. EBP is an exhaust back pressure sensor. It measures the pressure of the exhaust in the manifold. To do this is must be exposed to the exhaust via the tube. because exhaust runs through the tube it will look exactly like your tail pipe as it also has exhaust running through it. If anything the lack of the functional EGR may help reduce it. Hope this helps tried to put it simply.
Doug
stuckinMUD is offline
Old 03-11-2005, 01:34 PM   #3 (permalink)
rsd
If the soot is on the outside of the sensor, you have an exhaust leak. They probably created it when they changed out the EBP sensor the first time. Either that or the Y tube, or the tube leading to the EGR cooler.
'03 F-250 Crew Cab 6.0PSD
rsd is offline
