I KNOW THIS IS AND OLD QUESTION BUT............ - Diesel Forum - TheDieselStop.com
Old 03-08-2005, 10:54 AM   #1 (permalink)
hey i need advice from all the veteran 6.0 psd owners about what is the best oil to use i tow a 35ft 5er about 13k this is my 1st ford i used rotella in my chevy dmax, is this oil ok?? [img]/ubbthreads/images/graemlins/shrug.gif[/img] i have noticed a smell from the rotella i guess thats from the crankcase. smells strong when you are at idle and have windows down.. is this normal? also called dealer about changing oil before i go florida (i have 1700 miles on truck now)because of breakin oil he says ford runs there motors before they go to dealerships and drain breakin oil and put motorcraft oil back in what do yall think................ thanks
2008 F450 lariat 4X4 offroad 430 gears, dark pearl blue with gold trim everything but navigation, 92 mustang lx 5.0 coupe 375 hp wild strawberry, 03 harley road king classic,06 mustang gt (mrs pstrokes car) 2001 newmar kountry star 35ft triple slide (our beach house)....
LENSPSTROKE is offline
Old 03-08-2005, 11:06 AM   #2 (permalink)
My Photos: (31)
Send a message via AIM to DshiftFF
Re: I KNOW THIS IS AND OLD QUESTION BUT............
Rotella 15/40 year round. Synthetic is over rated. All the big trucks run Rotella with a million plus on them. I get a case (6 Gals.) for $36 at Sams club. Cant help you out on the odor, but thats my oil opinion.
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
I see a pattern emerging here
http://www.newenglandturbodieselpowe...rums/index.php
DshiftFF is offline
Old 03-08-2005, 11:21 AM   #3 (permalink)
AllOutFirefighter13's Avatar
My understanding on the break-in oil is that they leave it in. It is supposed to have a dye in it that will show up under ultraviolet light, in case any leaks arise during the first couple thousand miles. If I remember right, the oil is green in color. Good luck with your 6.0 and welcome to TDS!!!!!! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Joey
* '04 F250 XCab LWB 4X4 w/ FX4 *
* TorqShift *
* Manual 4WD *
* Carpet Delete *
* No. 2 ONLY *
* High-Idle Mod *
* Fumoto Valve *
AllOutFirefighter13 is offline
Old 03-08-2005, 11:54 AM   #4 (permalink)
Any CI-4 /4+ rated oil. I use Delo 400 & have had no problems. Rotella is good & meets spec. No problems.
Most guys will use synthetic in the cold areas.
OMCUSNR is offline
Old 03-08-2005, 08:34 PM   #5 (permalink)
I used Shell Rotella in my Dodge Cummins for 13 years. Always had an odor after an oil change. It went away after a week or so. Will be using Rotella in my new Ford also. I have that permanent smile now that everyone talks about when I'm behind the wheel! [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
2004 Black SC F250 XLT FX4 4x4 6.0 Torqshift
Flywheeler is offline
Old 03-08-2005, 09:43 PM   #6 (permalink)
Rotella here also. I paid to have the stealership change it at 2500 to get rid of the break in oil. The 5000 mile oil change was free. Both times the stealer changed it, I had a slight case of the romps. I have put Rotella in it ever since and no romps...
brokeagin is offline
Old 03-08-2005, 10:17 PM   #7 (permalink)
I changed my oil at 1700 mi, just to get the green dyed Motorcraft 10W-30 sludge out and it was noticebly green. I use Rottella T 10W-30 in the winter and 15W-40 in the summer and did in my 7.3s as well. I can not say that I have ever noticed any unusual smell from it though. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 03-09-2005, 12:10 AM   #8 (permalink)
It is my understanding that Ford puts 10W-30 oil in them at the factory with some oil dye for the inevitable oil leaks. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Daniel H.
Ford certified diesel technician (I'm a glutton for punishment [img]/ubbthreads/images/graemlins/smile.gif[/img])
No diesel at the moment due to lack of funds (thanks Ford/SLTS).
biginch is offline
Old 03-09-2005, 12:58 AM   #9 (permalink)
The Shell oil is fine, I generally use Delo 400 myself. The smell you get from the crankcase, is it engine oil smell or the smell of raw diesel?
My truck stinks of raw diesel from the crankcase, even though the level does not rise noticeably. Ford says "this is normal". Well I think they are full of it as I've NEVER smelled raw diesel from the crankcase of any diesel engine unless it had a problem!
'03, F-350 Lariet, CC, DRW, 5sp torquemaster, 4X4, 4.10ls, Sonic Blue monotone. Hijacker 16K full pivot/slider 5th wh hitch. One PRETTY truck [img]/ubbthreads/images/graemlins/wink.gif[/img] UPDATE: Truck is still performing poorly, though it is better since the last reflash that removed the EBP sensor inputs. Has definately been the worst truck I've owned in my 30 years driving Fords.
BigOne is offline
Old 03-09-2005, 02:10 AM   #10 (permalink)
Schaffers 5W40 Supreme 9000 and a Mobil 1 oil filter...good for 10000 miles and 1 mpg...
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
Mach1 is offline
Old 03-09-2005, 07:51 AM   #11 (permalink)
You're probably going to laugh at this one! I have a fleet of ford ambulances, and i use valvoline 15w40. I change oil and filter every 3000 miles, and a 55 gallon drum lasts me about 3 weeks. I have 2 '98 7.3's with over 300k, 3 '01's with over 200k, and 5 or six others with over 100k. I have NEVER had any internal engine problem with any of my trucks. I am a firm believer in changing oil more regularly than spending a fortune on oil and going 10k miles.
Fleet manager for (19) 7.3 PSD trucks and (6) 6.0 PSD trucks
2005 F350 Superduty, Crew Cab Dually, 4x4, 6.0 PSD
(Quite possibly the nicest truck I have ever driven!!)
gcaservice is offline
