I'm a believer in VC-9 look at this pic - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 32 (permalink) Old 04-07-2010, 08:00 PM
my local dealer wanted something like $35 per bottle of vc-9
here a better price
Motorcraft diesel engine coolant system iron cleaner VC9
FEBRUARY 2004 F350 CREW DUALLY,60K, 6.0L/6 SPEED/3.73/2WD,
EGR SPOOL, INSULATED WRAP CAC,BUTTERFLY DELETE,ACCUFAB INLET ELBOW,MUFF TUBE,BED COVER,BREATHER VENT MOD,OB1308 BY-PASS FILTER BASE,upgrade fuel return pressure spring 30# increase, velvet ride shackles, tranny cooler/filter,COOLANT FILTER,redline wetterbetter,1704A SUPERCHIP, SCHAFFERS 9000, 22MPG EMPTY @ 55MPH in cruise. Last fill up calculated @ 18mpg Hobbies- sticking my head out the window like a dog and hauling ass on the scooter rain or shine
pigsbreath is offline
post #17 of 32 (permalink) Old 04-07-2010, 10:09 PM Thread Starter
fonecop1's Avatar
I think I paid about $26 at my dealer. Also I used 2 quarts, I think it said not to use more than a 10% ratio so I figured since the coolant capacity is 27 1/2 quarts that 2 quarts would still be under the 10%. If you are flushing make sure to remove the block plug on the drivers side to remove about another gallon when draining. If you don't remove the block plug you will only get about 3 1/2 gallons by draining the radiator and removing the lower hose. To get the 50/50 mix you need to add 13 3/4 quarts of coolant so if you don't remove the block plug you may have trouble getting enough straight coolant in the system. The block plug takes an 8MM hex.
2004 F250 XLT 6.0 L
Crew Cab
119,000 Miles
1995 Chevy K1500
6.5 Diesel
335,000 Miles
fonecop1 is offline
post #18 of 32 (permalink) Old 04-08-2010, 01:21 AM
Arcticfury's Avatar
Thanks Guys.
Where is the block plug exactly located?
2004 F350 6.0 PS Crew Cab Lariat Edge Evolution (Just to monitor)
2005 Jeep Wrangler Rubicon
Arcticfury is offline
post #19 of 32 (permalink) Old 04-08-2010, 11:43 AM
69cj's Avatar
One on each side of the engine. Passenger side is behind the starter. You do not need to pull this one if you flush four or five times. The water will be clean. I went thru approx. 20 gals. of distilled water doing mine. Smart & Final has 2 1/2 gal. jugs for $1.99 ea.
2005 Lariet, 6.0, 3:73 1969 Mach 1, 428 CJ
1971 Triumph Trident(SOLD)
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
post #20 of 32 (permalink) Old 04-08-2010, 07:00 PM
Ok I have to ask the stupid question...How do you refill the radiator?
2003 CC SRW SB Auto 3.73
Mods:
REAR Air Locker
Kenwood DNX 7140
ISSPRO A Pillar Gauges
Femoto Valve
Edge Insight CTS
dieselhappy is offline
post #21 of 32 (permalink) Old 04-08-2010, 07:09 PM
69cj's Avatar
Cap on the degas bottle!
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
post #22 of 32 (permalink) Old 04-09-2010, 11:25 AM
VC-9 does a great job. I use it at the dealer after an oil cooler failure because it is about the only thing ive found to get all of the oil out of the cooling system. definetly recommend innstalling a coolant filter as well.
fordmasterdieseltech is offline
post #23 of 32 (permalink) Old 04-24-2010, 06:23 PM
After reading about all the things I have to do to my truck I am going to be busy. I have to ask....where do you purchase a coolant filter ? Thanks for the good info.
rschaub is offline
post #24 of 32 (permalink) Old 04-24-2010, 07:02 PM
ColoradoDoug's Avatar
It's been mentioned before to remove the t-stat to speed up the flushing process, but then usually stated to reinstall the t-stat when done. Why wouldn't you want to just replace the t-stat? I know on prior gas engines I've owned, when changing coolant, I would replace the t-stat with a fresh one. Could someone explain this to me please. Should I replace the t-stat when I flush my coolant?
Doug
______________________________________________
'03 Eddie Bauer 4x4 Excursion 6.0 Diesel
CCV mod
Upgraded turbo drain
Blue spring fuel pressure regulator kit
6.4 banjo bolts
v code front springs and modified b code rear springs
Bilsteins
Hellwig rear swaybar
'08 rear diff cover
4x2 liftgate struts
285 Michelin LTX A/T2's
tinted windows
DVD
XM
GPS
ColoradoDoug is offline
post #25 of 32 (permalink) Old 04-24-2010, 09:22 PM
OT
OT's Avatar
D..WAG on replacing t stat. is, its out/stick a new one in unless something obviously wrong with it. Its fairly easy to check out how T. works using boiling water/thermo., but probably not done anymore. JMO!
03 F250 XLT SC/SB 4X4 6L (stock) TqS. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
post #26 of 32 (permalink) Old 04-24-2010, 09:33 PM
My drain after the vc9 was no where near that dark, and i drove it on the interstate for 57 miles before i drained it.
05 4x4 CC, Harpooned Tank, 2 1/2 front leveling 1 3/4 rear, 285 nitto dura grapplers . , 03 Turbo , .129,900 miles dieselsite coolant filtration.
GJFord is offline
post #27 of 32 (permalink) Old 04-25-2010, 07:22 AM
FMTRVT's Avatar
My Photos: (16)
Originally Posted by ColoradoDoug View Post
........ Should I replace the t-stat when I flush my coolant?
Doug
That's up to you. There is not reason not to, nor is there one to replace a good operating one. Your call.
Jack
Truck Pictorials on Facebook. Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
post #28 of 32 (permalink) Old 05-04-2010, 09:56 PM
landis76's Avatar
Do you guys have a preference on the type of coolant?
2004 Ford F-250 King Ranch
ATC camper top
Edge CTS Evolution w/ backup camera
AFE cold air intake
Dieselsite coolant filter
Custom 5" exhaust
15" LCD w/DVD player
18" KR rims
Line-Xed bed
Remote start
landis76 is offline
post #29 of 32 (permalink) Old 05-04-2010, 10:45 PM
69cj's Avatar
Ford premium gold or Zerex GO-5 only.
2007 Road King flhp
2007 Jazz 5er, 11k
173rd Airborne
69cj is offline
post #30 of 32 (permalink) Old 05-04-2010, 11:32 PM
Just flushed my 02 and changed the t-stat at the same time. No reason to not to if you have kinda miles on the truck. Mine has 180k.
10 F-350 Lariat FX4
02 X 7.3l Ultimate Limited - SOLD
06 KR 250 4x4 - SOLD
a94cobra is offline
