i need help - Diesel Forum - TheDieselStop.com
Old 11-07-2012, 10:29 PM   #1 (permalink)
Send a message via Yahoo to mitchranger1
i need help
hi guys i need alil help i have a 07 f350 crewcab short bed diesel and my rear u joint is dead my problem is i cant get the rear part of the two piece drive shaft off at the rearend pinion flange it has four bolts holding it on and i cant remove them one of them is rounded off i am at a loss any suggestions you have will be helpful
mitchranger1 is offline   Reply With Quote
Old 11-07-2012, 10:34 PM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Can you grab it with vise-grips? I have a set of these too: Craftsman 10 pc. Damaged Bolt/Nut Remover Set, Low Profile Bolt-Out Reviews - Craftsman Community. Good luck.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. Many other custom features.
fordsforever73 is offline   Reply With Quote
Old 11-07-2012, 10:35 PM   #3 (permalink)
i tried that the bolts have a weird head on them
Old 11-07-2012, 11:10 PM   #4 (permalink)
My Photos: (21)
Those bolts should be a 12mm 12point head. I think they are loctited from the factory. If you have a fine tip propane torch, you could put a little heat to side of the flange where the threads are engaged and try.
Found this fyi: QU20103 Ford 12 Point Metric Driveshaft Bolt
Old 11-08-2012, 10:28 AM   #5 (permalink)
Work on stuff long enough and you eventually develop many techniques for removing stuck fasteners.
Always go to the blue wrench first. Heat works wonders. If the heads are still good, be sure to use the proper wrench. You can link two wrenches together to get additional leverage too.
If you have a stripped head then your options are vice grips or sometimes a Metwrench or similar wrench that puts pressure on the flats instead of the corners will work.
If you can't get a wrench or vice grips to budge it then it may be drill time. Use a good center punch and drill the fastener completely through to accept a tapered square bolt extractor. Drive that thing in tight and carefully wrench it out. I would heat it again as well to assist you.
Working around the driveshaft flange may make some of these methods implausible. If you have no other option you can always just grind the heads off to get the driveshaft out. Then you can work on the flange unobstructed, or even remove the flange and work on it on the bench. You'll have to re-set the pinion bearing preload when you put it back together, but that isn't a big deal. I can walk you through it if you need.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, Warren Diesel 175cc injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - shooting for the 12s!
'02 WRX - Outback rear disc swap, EBC green pads, pillar vane front rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline   Reply With Quote
