I think I broke a Flex plate - Diesel Forum - TheDieselStop.com
Old 11-18-2006, 10:41 PM   #1 (permalink)
Anyone ever break the flexplate??? Past couple of days I noticed my truck a little louder I shruged it off to cold weather then today when I slowed down at the stop light it sounded like the engine was going to throw a rod. upon acceleration noise stops truck runs fine / at idle truck runs fine just noisey. I got under the truck when I got home and tried to find the noise sounds like its coming from the bell housing area / Put my hand on the bottom of the bell housing and I could feel lots of vibration. Any thoughts on the matter???? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
03 F350
04 gearbox toyhauler
76 Wife
bilabronco is offline
Old 11-18-2006, 11:08 PM   #2 (permalink)
Re: I think I broke a Flex plate
Torque converter perhaps. My 7.3 just started making a simular noise recently. I kinda freaked the first time I heard it. It seems to be worst when the engine is warmed up and trans warmed up good too, only noisy at idle tho.
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip] Pics
SMOKESKULL is offline
Old 11-19-2006, 12:01 AM   #3 (permalink)
In a diesel engine such as this, a flex-plate with a significant crack(s) will make the most hideous grating/chattering racket you've ever heard. It sounds a lot like a lawnmower wrapped up with wire. The noise will be worst at idle, and decrease as engine RPM goes up because the crankshaft harmonics are most severe at idle and diminish with speed. I suspect you've hit the nail on the head with your diagnosis.
2011 F-350 Lariat, SRW, C.C., LWB, 4x4, Dark blue pearl metallic
2010 Montana Mountaineer 345 DBQ (5th)
PerryB is offline
Old 11-19-2006, 08:48 AM   #4 (permalink)
I hope its that. I also hope ford doesn't say "we warr the flywheel not the flexplate" Truck just hit 84,000 miles last week
03 F350
76 Wife
Old 11-19-2006, 12:14 PM   #5 (permalink)
i broke my flex plate, sounded like the exh. pipe was hitting the fire wall.....pulled a camper trailer from ok. to mn. and a few other trips,,,,,,1987 die., it got so bad that it finally said no.
jeb04 is offline
Old 11-20-2006, 04:17 PM   #6 (permalink)
Well Ford called... told me its my converter. Has anyone else had there coverter go out on them and if so what was the trucks symptoms. They quoted me 875.00 plus tax .
03 F350
76 Wife
Old 11-20-2006, 05:54 PM   #7 (permalink)
Wow, Ford called you? I thought the dealers did the work these days not Ford [img]/ubbthreads/images/graemlins/grin.gif[/img]
2005 F-350 6.0 PSD 4x4 XLT. Magnaflow 4" Turbo-back Exhaust. No other Mod's
ExR90 is offline
Old 11-20-2006, 06:11 PM   #8 (permalink)
Ha Ha very funny excuse me " The Dealer " called, is that better
03 F350
76 Wife
