I think I have a bad FICM - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 09-08-2011, 12:31 PM Thread Starter
The truck has had a stutter in it for a while now, mainly while towing, but it has gotten worse. I have noticed an exhaust smell getting stronger lately but there is no smoke of any kind at any time. I have replaced the FICM twice before but that was when the dealer said that was the issue. I have done the test on it and I have 48v not running and a steady 47.8v while running. I know this doesn't necessarily mean the FICM is OK and I think it is bad, but with the price of these things I thought I would ask and try to make sure before I just go buy one. I have not had a chance to buy a scanner yet so don't know if there are any codes. I replaced the alternator about 6 months ago and batteries are a few years old.I am hard on the batteries and do drain them occasionally as I work out of the truck a lot. Does this sound like the FICM is bad and if so would the repair for these things be a good option or should I just break down and buy a new one?
2013 F-350 SRW Crew Cab 6.7
2004 F350 DRW Crew Cab 6.0
Sheetrockman is offline
post #2 of 17 (permalink) Old 09-08-2011, 02:36 PM
What we also need is the cold start voltage off the FICM. Anything below 43.5 volts for more than a few seconds would indicate one going south so to speak. This electrical system depends on batts that are at or near a full state of charge. You may need to charge and load test them at least three times a year. Are you running an inverter? Post the cold start voltage when you can. Also run by one of the auto stores and see if you have any codes. Repair if bad is a great option! b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #3 of 17 (permalink) Old 09-09-2011, 12:52 PM Thread Starter
I rented the code scout 2500b reader from O'Reilly's and it says no codes and 2 of 3 readiness monitors ready. I have been watching videos on you tube and now I am wondering if the FICM is my issue or the ICP is. Any direction would sure be appreciated.
post #4 of 17 (permalink) Old 09-09-2011, 12:56 PM
U.P.Builder's Avatar
First test the FICM so you know if it's good or bad. It's very simple all you need is a voltmeter. FICM Testing Videos
2004 F250 4x4 Lariat Supercab longbox, blue spring, coolant filter, Cat ec-1, 75k miles.
1996 F-350 4X4 reg cab PSD, BTS trans, 3.55, Bills Chip, Tymar, DPP downpipe, urethane bushings, Bilsteins, 203 thermostat - gone
U.P.Builder is offline
post #5 of 17 (permalink) Old 09-09-2011, 02:54 PM Thread Starter
I have tested the FICM and I get 48v key on, 47.4v cranking and 47.4v running. It lopes along like it is getting fuel then no fuel, fuel no fuel, but doesn't normally die. If it does die then it will usually restart right away.
post #6 of 17 (permalink) Old 09-09-2011, 09:32 PM
FICM voltages look ok. Does the truck try to surge forward at all with the brake on like when stopped at a light? Also the exhaust smell you mentioned, see if you can grab a telescoping mirror and check the firewall area for sooting. Check for a cracked y-pipe.
post #7 of 17 (permalink) Old 09-10-2011, 12:34 AM Thread Starter
The truck does not lurch at all. it just runs, dies, runs, dies at idle and even when rpm is up but does not lurch in any way.
post #8 of 17 (permalink) Old 09-10-2011, 04:20 AM
BWP3000's Avatar
I have recently had this problem. I would strongly recommend that you look at the ICP sensor, because the FICM relies on what the ICP tells it. I have an 03, and for that year the ICP was known to go bad and screw with the FICM. I just got the problem fixed today and my truck has been running MUCH better. Have yet to cold start it, but I think this probably fixed the issue.
ICP sensor and install was 250. Mechanic said you have to sometimes get a new wire harness with the new ICP sensor (my sensor was leaking).
Good Luck!
BWP3000 is offline
post #9 of 17 (permalink) Old 09-10-2011, 04:37 AM
brettrose99's Avatar
Just curious about your inquire about the truck surge at a stop and brake on... Mine just started this. What could cause this? I had a bad FICM 48V before cranking, 24V while running. cold starts= fire up and die, kill the batteries trying to get running unless truck was plugged in for a couple hours. Temps about 35 here at night. Thanks for any info!
2004 Ford F350 Mods: Fabtech 6"; 4 1/2" turbo back exhaust (no cats); 20" Mickey's Classics; 40" Mud Grapplers; Banks Six-Gun with loader; Polk Marine component sound system; Pro-Comp front/Rear Ladder bars and of course, the K&N ha-ha
brettrose99 is offline
post #10 of 17 (permalink) Old 09-10-2011, 06:52 AM
Truck surge at idle with the brake on would indicate a failing icp sensor and harness. The surge is quite noticeable! 24 volts cranking on the FICM with good batts. would indicate a bad FICM. Sheetrockman, I would check the fuel filters. how many miles on them and are they oem/racor?
post #11 of 17 (permalink) Old 09-19-2011, 09:13 PM Thread Starter
Filters are clean and I dont remember if they were OEM or not. My truck dies not move with this issue I am having in the engine. It is a die, run, die, run and will do it at 70 mph or just sitting at the stop light.
post #12 of 17 (permalink) Old 09-22-2011, 03:34 PM
Send a message via AIM to JVogel
Joining the ranks of FICM issues
Mine was only evident on starting. Cranking longer and longer on some starts and then just like normal on others. I had my truck in for Oil and Fuel filter change and they discovered that I have a FICM showing failure. So now Its sitting for a week since my Air Handler at the house decided to go out the same day. I will be glad when this week is done. I have to fix the AC at home first, then I will get the FICM and hopefully EGR delete done at the same time.
Jeff
2005 F250 Lariat 4X4 Crew Cab factory 17's Ranchhand Full Replacement front and Back.
Toy 2006 HD Ultra Classic
Oldies and Missed
99 F250 4x4 Deep Wdgewood Blue (Favorite)
97 250 4x4 Red
94 F350 Crew Cab 4x4 but 460 ga$$er
JVogel is offline
post #13 of 17 (permalink) Old 09-22-2011, 05:01 PM
spedkid94's Avatar
FICM modules ususally put out a P0611 which is a FICM module code. We call that the FICM code of death. You can try reprogramming them but it usually will only be a temporary fix. Usually bad modules are noticeable from multiple injector codes. The only way to really diagnose a 6.0L misfire is with Fords IDS tool. Our shop bought one to help with injector issues. If you end up getting a FICM module the book time (that includes programming) is 2 hours and the module runs around $750.
2011 F-250 XLT CC Blue
Toyo M/T on Fuel Hostage 20", AMP Steps,
Extang Solid Fold, Recon LED Brake Lights,
Recon Projection Headlights, AFE Exhaust,
Katzkin Leather, Smittybilt M1 Grill
Bilstein 5160 Shocks, 20" Rigid LED Light,
Firestone Airbags
spedkid94 is offline
post #14 of 17 (permalink) Old 09-22-2011, 05:12 PM Thread Starter
Took it to the dealer and it turned out to be a stud wore through and shorted a wire in the harness.
post #15 of 17 (permalink) Old 09-24-2012, 08:46 AM
I have the same
I May have the same problem. Do you have any info on what stud, What wire??
jhelms is offline
