Icp Problem Need Help Fast - Diesel Forum - TheDieselStop.com
Old 01-26-2010, 08:50 PM   #1 (permalink)
Have Problem With Icp On A 2003 F250 6.0 Need Help To Determine If This Is The Problem And How To Fix It I AM NEW TO THIS SITE NOT SURE HOW NAVIGATE SITE JUST YET PROBLEM IS ROUGH IDLE RPM GOES UP AND DOWN WITHOUT PRESSING ON THE PEDAL AND CHECK ENGINE LIGHT IS ON. TOOK TRUCK TO AUTOZONE AND THEY SAID THAT THIS WAS PROBLEM.
LDOGF250 is offline
Old 01-26-2010, 09:07 PM   #2 (permalink)
Supporting Member
my03psd's Avatar
Need some info, what is the problem you're having?
3/28/03 F250 6.0L PSD ,TORQSHIFT,CC,SB,FX4,LARIAT
Charcoal Gray/Black,
Tint,RhinoLined,Sirius,Roll&Lock,Strobes,
SCT X3 Custom Tuned by Innovative,
MBRP Stainless 4" Turbo Back,
ISSPRO Pyro,Boost, & Trans Gauges
Prodigy Brake Controller,Remote Start and Turbo Cooldown,
High Idle Mod., PM-13A on the Oil Pan,
HFCM Plug Upgrade,DieselSite Coolant Filter,
Energy Suspension Bushings,& Stanadyne every tank
my03psd is offline
Old 01-26-2010, 09:15 PM   #3 (permalink)
ROGH idle and bad rpm fluctuations without pressing on the gas pedal
LDOGF250 is offline
Old 01-26-2010, 09:19 PM   #4 (permalink)
also need to know what it is what is does and if this is the problem how to repair
LDOGF250 is offline
Old 01-26-2010, 10:05 PM   #5 (permalink)
Supporting Member
my03psd's Avatar
It should be your problem.It leaks oil around the sensor and swells the wire, giving a false reading ,causing the concerns you are having.On your 03 the ICP sensor is located under the turbo.Here's some info on it...Page 61: Electrical Components
Check this out too How to replace early ICP - with pictures
my03psd is offline
