ICP replace - Diesel Forum - TheDieselStop.com
Old 10-11-2009, 09:47 AM   #1 (permalink)
ICP replace
I'm about to replace my 2nd ICP sensor p/n 3c3z-9f838-ea on my 03 f250 . The truck has 90k miles on it .My question is do I replace it with the same part number or did Ford/International improve this faulty design with a new improved sensor with a different p/n .
beallright is offline
Old 10-11-2009, 10:34 AM   #2 (permalink)
They must have improved this sensor. Its a plastic core sensor with a plastic connection mounted under the hot section of a turbo next to a exhaust Y pipe then pressurize it with hot oil .
Old 10-12-2009, 12:39 PM   #3 (permalink)
rsd
They did, but I don't have it at hand. Search will get you the right number.
'03 F-250 Crew Cab 6.0PSD
rsd is offline
Old 10-12-2009, 04:47 PM   #4 (permalink)
w_huisman's Avatar
If the ICP is leaking oil into the connector, you might also want to replace the pigtail as well.
2006 F250 6.0 Lariat
cc sb 4x4 auto 67k, coolant filter, analog FP gauge + Edge Insight w/ EGT. VXCF9H7 strategy
All else stock.
w_huisman is offline
