If it was a horse I'd shoot it!!!!!! - Diesel Forum - TheDieselStop.com
Old 07-23-2009, 05:44 AM   #1 (permalink)
I have a 2004 psd. It has been a great truck for over 122,00 miles. Now in the last two days I have thought about vehicular homicide (shooting it). It started by blowing very black smoke on acceleration. That moved on to some of the hardest shifting I have ever witnessed. Well I decided on talking to a pro about these things. Went to Ford house and he seen my tuner and immediately said it was cause of that. Realized I was going nowhere fast started reading some of these posts and today I pulled my EGR valve and cleaned it. My next question is where is the IPC and where can I find the *%$hole that thought it was funny to hide it. Thanks in dvance!!!
ballzout 04 is offline
Old 07-23-2009, 07:17 PM   #2 (permalink)
william_04_X's Avatar
if you have a late 04, the ICP sensor will be on the front and top of the pass. side valve cover..
If it's an 03/ early 04, it'll be under the turbo and accessable from the drivers side.. I changed mine recently... Click here..
also, what leads you to ICP? sounds more like a bad injector, if the smoke is really heavy under any throttle input.. if so, get it fixed ASAP.. a leaking injector can fill the crankcase with fuel and possibly hydro the hole..
04 EB X w/03 PSD
william_04_X is offline
Old 07-23-2009, 07:26 PM   #3 (permalink)
I ran the codes and it was 2285. And yes it is a early 04.
Old 07-24-2009, 12:09 AM   #4 (permalink)
If I am at a dead stop with my foot on the break it will try and take off without any warning. It also idles pretty rough . I appreciate your response william 04x and those are really great pics. So what was yours doing that made you think it was your ICP? I guess I could tell you that my truck has a superchip tuner,magnaflow 4 inch exhaust,k&n intake and I only run wix oil and fuel filters. I don't know if this will be any help to anyone,but I will take any and all advice to heart.
Old 07-24-2009, 06:05 PM   #5 (permalink)
same symptoms as you described, and 2285 code...
04 EB X w/03 PSD
Old 07-24-2009, 08:37 PM   #6 (permalink)
Thanx I was hoping u would say that.
Old 07-24-2009, 09:01 PM   #7 (permalink)
Lots of posts on WIX filters. They aren't doing your vehicle any favors. I know, most people will bristle up and say prove it. Just take some time and research it. Filtration and fit are best w/ OEM style filters (Motorcraft, Racor, International, and some Frams (but not all)).
Mark
bismic is offline
