Old 05-05-2005, 02:36 AM   #1 (permalink)
PoneyXpres's Avatar
Info about it being a 6spd
http://www.motorcraftservice.com/vdi...p;menuIndex=18
http://www.motorcraftservice.com/vdi.../Dobdsm304.pdf
Found this to be a suprise.
NOTES: 5R110W has a feature called "Cold Mode". If TFT is below 0 deg F, the transmission will limit
operation to 1st, 2nd, 3rd, and 4th gears (5th and 6th gears are disabled). Cold mode remains in effect until TFT
rises above 0 deg F or vehicle operation (based on shift times or heat generated by driving) indicates that
TFT should not be in the cold mode range, at which point normal operation is enabled.
I searched for a while to find this and couldn't find the thread where I wanted to post ot so I made a new one.
PoneyXpres is offline
Old 05-05-2005, 10:48 AM   #2 (permalink)
Re: Info about it being a 6spd
I read on here a couple days ago in some post that the tprqushift is technically a 6 speed. The extra gear isnt always used though or something to those effects. I cant remember exactly, I didnt pay muhc attention to it since I dont have one.
2004 F-350 Reg-Cab XLT, 4X4, SRW, 6.0 PSD, 6 speed, manual transfer case, Dark Shadow Grey, 285/75R16 Cepeck FC-II's on 16X8 Centerline wheels. built 3/23/04, 80k miles.
Canyonero02 is offline
Old 05-06-2005, 01:03 AM   #3 (permalink)
There are six possible (programmed) gear selections. In any shift progression from low gear to high gear, only 5 are used.
GrampyJim is offline
Old 05-07-2005, 04:01 AM   #4 (permalink)
Grampy_Jim:
Is that as in 5 forward and 1 reverse for a total of 6 programmed?
'03, F-350 Lariet, CC, DRW, 5sp torquemaster, 4X4, 4.10ls, Sonic Blue monotone. Hijacker 16K full pivot/slider 5th wh hitch. One PRETTY truck [img]/ubbthreads/images/graemlins/wink.gif[/img] UPDATE: Truck is still performing poorly, though it is better since the last reflash that removed the EBP sensor inputs. Has definately been the worst truck I've owned in my 30 years driving Fords.
BigOne is offline
Old 05-07-2005, 10:34 AM   #5 (permalink)
It's 6 forward speeds and a reverse. Its like old c6 (3 speed auto) and a Gear Vender Overdrive, only electronic controls.
It is a combination of 2 xmissions in one case.
You get 1st, 1st over drive, 2nd, 2nd over, 3rd and 3rd over for six gears. Ford does not use 2nd over or third depending on temperature, giving you 5 speeds.
2003 F250, 6.0L, Torqueshift, short bed, supercab, 4x4, build date 1/05/03 (stock)
1997 Lincoln Town Car
33 ft Newmar Kountry Star 5er
jsglick is offline
Old 05-08-2005, 07:32 PM   #6 (permalink)
Ah, ok, an automatic version of say a Fuller 10sp, I get it. Internal split.
Thanks.
BigOne is offline
