injector cleaner - Diesel Forum - TheDieselStop.com
Old 10-23-2009, 06:57 PM   #1 (permalink)
mmterrill's Avatar
injector cleaner
just got back from reflashing my truck and seeing if that helped my issue with buckin and jerking but with no luck. so i decided to have them check the injectors and cyl 2 and 5 arent good under a load but fine when at idle. we ran the truck in tow mode trying to get it hotter to see if that made a difference and it was very little. but when he hooked it up to check the egr system it showed that it was 85C which he said was too cold and the thermostat may be hurting it also by not getting hot enough to let the injector cleaner work. plus my mpg is 14.7 with no trailer but running it hard. and when i havent ran it hard its only 16.5 or so. he said the thermostat could be causing that as well or at least not halpin me. what temp should it be? how can i check the thermostat to see if its workin? if you guys dont think thats it was is a great injector cleaner. ive tried to hunt someone with a wynn injection cleaning machine but nothing. thanks.
mike
mmterrill is offline
Old 10-28-2009, 05:28 PM   #2 (permalink)
mmterrill's Avatar
come on fellas any ideas. do you think a injection cleaning would fix my problem? anyone else had this problem and how did you fix it? besides takin one up the a** from a dealer. thanks.
Old 10-28-2009, 06:08 PM   #3 (permalink)
teamroper60's Avatar
I have to admit to being somewhat lost on your original post... I am not familiar with so-called "injector cleaners" so I have no idea how they work. That said, I am not sure what the thermostat has to do with any of this. To actually clean the injectors, the "cleaner" would need to be in the fuel, which should not ever be coming in contact with the coolant.
What's more, I have no faith in these "injector cleaners" in the first place. Diesel is something of a solvent itself and it is flowing out of the nozzles which is the only thing that could be cleaned by these "cleaners". If your injector nozzles are clogged by something that diesel fuel and fire/heat won't clean off through normal use, there is an underlying mechanical problem that needs addressed.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 10-29-2009, 11:56 AM   #4 (permalink)
MelloMike's Avatar
My Photos: (13)
You didn't say what year your truck is, but I had the same problems you are having. But my truck was even worse, it reached a point of being plain gutless. I have 115,000 miles on my Excursion. I tried injector cleaners and they helped a little but what REALLY helped was a jug of Hot Shot Secret oil additive. THIS STUFF WORKS. It cleans your injectors and eliminates "stiction". Google it for more info and there are a few threads on this site for Hot Shot. All I can say is that my old truck is back and runs fantastic and no, I don't own stock in this stuff.
2003 Eddie Bauer Excursion (born 8 Apr 03), 6.0L PSD (Oxford White & Arizona Beige), 117k miles and going strong, C95 Fuel Injectors, 4x4, 5-spd Torqshift, 3.73 Rear, Heated two-tone leather seats, Hellwig Rear Sway Bar, Bilstein Shocks, PSD Badges, Tekonsha Prodigy Brake Controller. Engine Repairs: 2009-ICP and ICP Harness & Exhaust Y-Pipe. 1972 Airstream Sovereign Travel Trailer.
US Navy Retired
MelloMike is offline
