intake manifold cleaning - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-05-2012, 05:28 PM Thread Starter
I'm changing my oil cooler and just removed the intake manifold. Looking inside there's a lot of gunk.
Is there any value in cleaning it?
It there a recommended method?
Anything to beaware of?
I'm getting back on the truck, I'll check back in a few hours.
Thanks in advance.
/r
Todd
2003 F350 6.0L crew cab 4x4 dually
2002 Indian Chief Deluxe
te805 is offline
post #2 of 6 (permalink) Old 05-05-2012, 06:04 PM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
When I brought my heads for machining, the guy told me to bring the intake manifold with me and he would hot tank/clean it at the same time as the heads. Not a very easy thing to clean for sure. Good luck.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #3 of 6 (permalink) Old 05-05-2012, 08:55 PM Thread Starter
Good advice, I'm going to look into it.
Oil cooler cover "looks" like it has cracks all over it. My buddy says they're just casting lines. One of the threaded posts is broken and was only held in by the helicoil. The cover is going to get replaced.
te805 is offline
post #4 of 6 (permalink) Old 05-05-2012, 08:57 PM
Cetane Man's Avatar
Intake cleaning
Thanks in advance.
/r
Todd
I'm in the middle of my oil cooler now. ought a can of Gunk Engine cleaner and followed directions on the can. I wasn't completely satisfied so I took the intake to my local car wash bay and used the engine cleaner feature with the high pressure warm rinse. Came out pretty good. I did however remove the air temp sensor, you don't want cleaners and solvents getting inside these sensors! When I got home I hit it again with Castrol Superclean a brass brush and I am happy with the extended effort I put in. Have fun...
2006 F-250 6.0 Crew Cab
Red ELC Coolant, Sinister Coolant Filter, CCV Re-route, 6.4 Fuel Banjo Bolts, Fuel Regulator Blue Spring Update, Tint, High Idle Mod, Zoodad Mod, Kenwood, Infinity, Autometer, 4" MBRP Turbo back, No Cat, Sinister EGR valve & Cooler Delete, SCT SF3, Garrett Stage 1 Powermax Turbo, Updated 1 Pc. STC Fitting, Fumoto valve, Updated FORD Oil Cooler, Gates Fleetruner Belt, Blue Anodized Fuel & Oil Caps, HFCM Plug upgrade, DEI Thermal wrap
Cetane Man is offline
post #5 of 6 (permalink) Old 07-18-2015, 07:35 PM
My Photos: (16)
How long would a new EGR last if you don't pull the intake manifolds to clean. Only 135,000 k on truck. Don't want to pay eight hours labor if there is another option.
2002 F250, PSD, Lariat 4x4, Crew Cab, Long Box, Born 2/02, Oxford White/Silver, SRW, 3.73 Rearend, Towing Pkg, Auto Transmission, Roll-n-Lock Cover, Billet Grille, BFG A/T 285's, Husky Mats, VDO Pillar Mount Gauges(Pyro,Boost,Tranny Temp.), Magnum Force A.F.E. Filter, DiabloSport PowerValve, Amsoil Fluids, 700 Watt Power Inverter, STOLEN FROM MY DRIVEWAY!
2005 F350, PSD, XLT 4x4, Crew Cab, Long Box, Silver (and that is all I know)
2015 Harley-Davidson FLHX
bertturtle is offline
post #6 of 6 (permalink) Old 07-19-2015, 12:42 PM
I ran the parts washer through mine and used some stiff bottle type engine cleaning brushes in the passages. It got the worst of it out, at least anything that could clog anything up. The intake takes a beating from the soot in the exhaust gas combined with the oil coming in through the crankcase vent system. Black sludge is the order of the day. Re-routed CCV and no more EGR and it stays nice and clean.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ ID custom tune, FASS 195 pump, Gillette Diesel EGR cooler delete, Sinister Diesel coolant filter, ELC coolant, updated turbo drain tube/oil feed line/STC fitting/oil cooler, ARPs w/OEM HGs, Elite coolant lines, ITP RR fuel system, RCD 175/30 injectors, Powermax, BD CCV, FICM.com FICM w/ ID tune, Elite UP, BPD water pump - 13.069 @ 101.94
'02 WRX - Outback rear disc swap, EBC green pads, DBA pillar vane rotors, TXS UP/TBE/TMIC, Perrin LW crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel & clutch, K&N filter, STi Group N motor/trans mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune for Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
TKOPerformance is offline
