Intermittant Battery Light flash? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 12-16-2009, 10:31 AM Thread Starter
04 F350 6.0 Iv'e had an ittermittant battery flash off/on few past few months. Never had a dead battery set, always started in the am....terminals appear to be clean, no corrosion.... thoughts please....
Shawn West is offline
post #2 of 9 (permalink) Old 12-16-2009, 12:22 PM
saline's Avatar
Me too,
Does your light flicker while on bumpy roads?
I have a battery flash as well, especially when on bumpy roads. I have checked the battery connections, alternator connections, power distribution box connections, and the #14 fuse under the dash. No luck yet. I hope you can find your problem. I have a Ford service troubleshoot for this problem but I am having trouble finding out where circuit # 35 connection is. Let me know if I can help.
04 E 350 Sportsmobile 4x4
6.0L PSD
315/75/16 Toyo Open Country MT's
Dynatrac 60 front/ Dana 70 Powr-loc rear, 4:10's
Atlas II x-fer case
Coolant filter
saline is offline
post #3 of 9 (permalink) Old 12-16-2009, 02:26 PM Thread Starter
intermitant battery warning light
I also had the Ford house do a check, of course they found nothing. I guess i will pull and clean retighten battery terminal connections...strange, i made a 1800 mile trip to lower Alabama with zero flash....need to become a member of AAA...
post #4 of 9 (permalink) Old 12-16-2009, 03:33 PM
Thought there was a post a few weeks ago in the 6.0 or 6.4 section about the alternator getting flaky, with a cracked or broken bridge in the back of the alternator. I would be inclined to remove the alternator and look it over real good, and have it load-tested if you can. just a thought. I replaced my alternator in my 2000 4 years ago in January. It checked out ok on the load tester, but, I was in zero degree weather, with a set of 3 year old Duralast batteries that were questionable (found this out when the truck wouldn't start in zero degree temps). Since I was 750 miles from home, I went ahead and put in 2 new batteries and a new alternator, and all has been fine since. Also, check the battery cables really good. I had a set of cables on a Nissan truck that looked ok at the terminal. The charge light kept coming on, so I replaced the alternator, only to find out (after the fact) that the cables were half-eaten up inside the wrapping. After that experience, I always check the cables as far as I can get the wire exposed to see if there is any rot/calcification going on.
just my .02 cents worth
short-stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, BAK RollX bed cover, Bed mat, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, undercoated, 156k somewhat trouble-free miles (so far), Edge Evolution (60 HP setting), Pioneer DVD/CD/iPod/XM satellite, backup camera
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2) and tension pullies, all 4 power lock actuators, water pump, air conditioning lines and compressor, battery cables, replaced the leather oem seat covers with very good leather replacements (found a great place and price from a place in Dallas that custom makes them)
2016 Subaru Outback (Wife's commuter car)
2016 Starcraft Autumn Ridge 29ft TT
short_stuff is offline
post #5 of 9 (permalink) Old 12-16-2009, 04:39 PM
Voltage Regulator?
My 06 6.0 had the flicker for ages...ignored it and then she wouldn't start one day.It was the VR (integral to the alternator I was told).
Maui Stroker is offline
post #6 of 9 (permalink) Old 12-16-2009, 05:14 PM
My light on my 04 would flicker under heavy accleration about 3 weeks after I noticed it the batteries were dead. I took my alternator to Advance auto parts and had it tested. It was completely dead, after I replaced the alternator it was fine no more light and no more power problems.
Neiro is offline
post #7 of 9 (permalink) Old 12-16-2009, 05:37 PM
saline's Avatar
What is this integral to the alternator you speak of? Inquiring minds want to know.
6.0L PSD
Atlas II x-fer case
Coolant filter
saline is offline
post #8 of 9 (permalink) Old 12-16-2009, 06:07 PM
Voltage regulator im guessing
Neiro is offline
post #9 of 9 (permalink) Old 12-16-2009, 06:29 PM Thread Starter
Thanks, a lot of good info to work with, I appreciate the responses from all hands. Will make a trip to get a load test, wish everyone a happy holiday and a Merry Christmas and Happy new year....
