Intermittent loss of boost while towing
First post on this forum so don't flame me too bad.
I have searched a little, found some of my symptoms but not all.
My truck is an 03 f350 4x4 6.0 torqueshift trans, 83000 miles, edge with attitude programmer.
My primary problem is while towing into the mountains, the pull always starts good running 65-70 up the hill, usually within 1-2 miles into the pull the boost will start dropping from 26-28psi down to 8-9 psi and stay there speed drops down to around 30-35 rpm around 3200-3500 2nd or third gear. Get to the top of the hill starts picking up again runs fine for a while it may pull the next hill without any problems or it may do the same thing again.
Second problem happens around town, cruising 50-60 on a slight incline, roll slowly into the throttle I get a slight bucking condition, lift out of the throttle it goes away.
New EGR valve, new hp oil pump, turbo cleaned 6 mo ago, air, fuel and oil filters all changed 1500 miles ago.
I thought it might be the edge so I uninstalled it, but it still does it.
No codes stored.
Thanks in advance for any info.
