Intermittent runs, rough, low power, EGR,FICM? - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 04-20-2017, 12:06 PM Thread Starter
Supporting Member
Hi All
I posted a while ago about the codes I had. Thanks everyone for the input. Sorry I had no updates work had me away and busy.
I pulled the EGR yesterday. It was very dirty, full of cruddy soot, so was the chamber. I could put my finger in the one cavity and it felt like it was full of this soot and crud also. This EGR is only about a Year old. Is this normal? I also checked the FICM with a volt meter. This FICM is only 2 yrs old, re built from circuit board medics. Key on read - 47.5 V Start and running read - 47.8v.
When not up to running temp it lacks power. Some times when it IDLE's it is very smooth and sounds good but other times I can hear it stutter every 10secs or so.
I feel like this is and electrical issue. Also I should note as I wrote in my last post, the instument cluster is off and on - The plug has loose connection or something, I can wiggle there and it works.
Yesterday it acted like it was running out of fuel. Then 3 hrs later went to take it out after looking at EGR and FICM and it run really good. But with no instrument cluster.
Any advice would be appreciated.
Bigaldiesel is offline
