IPR messed up? - Diesel Forum - TheDieselStop.com
Old 03-29-2009, 11:58 AM   #1 (permalink)
rsd
IPR messed up?
Almost done with the Hellish ICP replacement, but I noticed that the plastic top of the IPR is loose. Did I goober it up while I was wrestling with the ICP, or is it always loose? I'm going to finish putting everything back on and seeing if it runs OK. My guess is that I may need to get back in there and replace the IPR as well on Monday. How much does an IPR run? Is it something dealers keep in stock? Thanks.
'03 F-250 Crew Cab 6.0PSD
rsd is offline
Old 03-29-2009, 02:11 PM   #2 (permalink)
$350 for the IPR from Ford.
mainseal is offline
Old 03-29-2009, 06:31 PM   #3 (permalink)
rsd
It's all back together, and all is good, except that while I was gorillaing around at the back of the engine, the plastic cap on the injector closest to the driver chipped, so I'm not getting any fire on that cylinder. I'm kicking myself at this point. I'm starting a new post with an accurate subject line.
rsd is offline
Old 03-29-2009, 09:57 PM   #4 (permalink)
rsd
Thank goodness, the IPR is still good. I did bend, or push in a pin or two on one of the FI connectors. I'll check it in tomorrow.
rsd is offline
