Just cleaned my egr valve - Diesel Forum - TheDieselStop.com
Old 07-14-2009, 05:12 PM   #1 (permalink)
My 2004 shows 2 codes on egr valve. It has no power at all. I cleaned the egr today and nothing changed. Do I need to just buy a new one or any of you have any ideas. My Ford dealership recomends that I send out the intake to get special cleaning. Any of you heard about this? It also costs about a $1000.00
onyx is offline
Old 07-14-2009, 06:37 PM   #2 (permalink)
Many times cleaning egr valve is not very effective. If you still have issues after cleaning, you will most likely need to replace valve. Ford no longer recommends cleaning if they are sticking, they recommend replacement. Our dealer has been hit up about an intake cleaning procedure that runs chemicals through intake to remove carbon deposits. We felt it was overpriced and sceptical about how effective it would be. For what it cost to perform procedure, I would recommend removing intake and steamcleaning. With intake off and steamcleaning, you can visually see that the carbon/coking is removed from intake.
djshum is offline
Old 07-14-2009, 06:49 PM   #3 (permalink)
yeah replace the valve. most dealers are doing the bg service, i think it works pretty good, i always steam clean an intake when i have it off for a repair but that still doesnt always get it all out. But with the induction flush you get the ports in the heads and the valves which also get allot of build up, and it also take care of the exhaust side like the veins in the turbo and inside the egr cooler. bg also has a fuel injector flsuh and oil flush and i think if you do all three which includes an oil change, i think that usually costs close to 1000. but i think at my dealer the intake flush is around 550?
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 07-14-2009, 08:59 PM   #4 (permalink)
To keep costs down, do you think I would be OK just putting the new egr in and not cleaning the intake?
onyx is offline
Old 07-14-2009, 09:12 PM   #5 (permalink)
Look down in intake once valve is removed. If there are excessive deposits, break loose what you can and vacuum out of intake. That is all we do at our shop. Only time intake is cleaned/steamcleaned is when intake is removed for engine repairs.
djshum is offline
