You Guys will find that the install on this is quite simple. One thing I would have done different from the instructions was to have the filter screwed onto the housing and the 3/8 line connected to the front of the housing and to the tee so that when you splice in the tee it is a "quick" interruption and only a minor loss of coolant. Don't forget to have the clamps in place and ready prior to the tee splice. Nice setup that I am certain will make a difference.
In the end we will remember not the words of our enemies but only the silence of our friends
2006 F350 C/C SRW S/B Lariat FX4, SCT X3 W/ID Custom tunes, Coolant Filter, CCV Mod, High Idle Mod, fog light mod, EGR Delete, 3.5" MBRP stainless Downpipe, 4" MBRP Stainless the rest of the way, Swamps FICM,Edge Insight Gauges,18" BFG'S, 120k
I would like to also give Bob at Dieselsite 2 thumbs up! I bought the filter kit and installed one of my filters [I bought 3] and it would not stop leaking. I called Bob and not only did he replace the one filter he gave me a total of 4 new filters! Wow thats customer service! Thanks Bob!
I have had mine sitting in the cellar for about a month now uninstalled...
My questions:
How far off the engine connection do you cut the larger hose?
I am pretty confident about the cut on the return from the top of the radiator. But the larger hose on the engine looks tight? The directions are a little foggy I think a measurement would help. Any input?
What do you cut the hose with to ensure a clean cut?
2005 DWL SB Crew 6.0 w/tow command, 4:10 rear end. FICM Repair @75k, (Gift from 7/200 coverage) ScanGauge II, Banks Ram air intake, Coolant Filter, Banks exhaust, ARP Bolts. The whole OASIS would never fit here!
Munfrobie I cut my hose around the area of the oil fill cap just behind it a little ways up the hose. I used hose cutters I have but a razor blade will do. I pinched off two sides of the hose with some needle nose vise grips and only lost the amount of coolant in the section I wanted to cut. I just cut the hose about the size of the the tee in length. You can always cut on the longer so you will have enough. It was very simple. Install was about 1 hour. It really should have been less but I was making sure all was good along the way. I can email you some pix of mine installed if you like. Pm me your email and I will get it out to you.
When I installed mine, the engine was dead cold (3 days) and the coolant loss was about a teaspoon. I had drip pans under the van, prepared for the worst, but really to leaks. When the engine is cold, there is no pressure to force out the coolant.
And the P/U heater hose is easy access compared to the van. I couldn't even see the heater hose to start with. And no room for big hands.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
I ordered mine about a week ago... I dont' have it yet as I got mine shipped to my house and it just hasn't arrived..
Is there a specific filter to these kits that I can buy here or do I have to buy the Diesel site filter? If I have to replace the first filter that soon I am just trying to be prepared with some extra filters..
2003 F350, 6.0L Lariat 267,000kms, Stock except for the Pioneer in dash Nav unit with Back-up Camera... STOLEN May 16th, 2011. Still looking for her replacement **** Got my truck back from the Insurance company.
The filter is a Baldwin 5134. Everyone has a cross reference for it.
Mike
Thank you for the link. I ordered mine, and the ball valves, and 3 extra filters, last night. I hope to install it as soon as possible.
I just placed the exact same order for my '03 Excursion. I really debated on buying this because I already have > 120K miles on the vehicle, but I guess it won't hurt. Plus I'll be all set to protect new EGR and oil coolers if I end up having to replace the originals sometime down the road. Since nobody makes a big people hauler that can also tow heavy trailers, I hope to keep the Ex for a long time.
-- 2003 Excursion EB 6.0L
-- 2008 F350 CC SRW Short Box 6.4L
The connection to the heater core discharge tube... I teed that line in back near the firewall. Much easier to keep an eye on there than down below the intercooler tube.
There's probably a reason I shouldn't have done it that way, but after 15k - 20k miles it still works fine.
__________________ 2006 F250 6.0 Lariat
cc sb 4x4 auto 67k, coolant filter, analog FP gauge + Edge Insight w/ EGT. VXCF9H7 strategy
All else stock.
I looked at putting mine there and ended up not doing so because folks said not to. If I recall correctly, the reason was because it will only allow for filtration when the heater is on....
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; Silverline turbo-back dual exhaust; 155cc injectors from Full Force Diesel (Casserly); SCT with tuning by Tony Wildman (Total Diesel Performance) & Innovative Diesel; ARP studs; Dfuser regulated return; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT; JL Audio 275w amp driving a 12" sub; JL Audio 50wx4 amp driving the Alpine door and rear seat speakers. 380.3hp/786.7ft-lbs (on my tow tune!)
Hmm... I thought I teed into the same hose that the kit recommended, just further back closer to the fire wall. And I thought it was the heater core discharge hose. I'll have to take a look again and see if I'm mistaken.
All else stock.
The directions read if you have the solenoid in the heater hose, connect forward of it. If not, you can connect anywhere in the hose's run.
I chose a section of hose in front of the solenoid, but in a straight section of 3 or so inches, so the t-fitting/hose wouldn't be bound up in a turn in the hose.
2004 F-350 Lariat, ~ 131,000 miles
2WD Crew Cab, Long bed, Dually, 6.0L PSD, Automatic
Done: Sirius Satellite Radio; Coolant Filtration System; Prodigy Brake Controller; 4" Turbo-Back Exhaust, cat delete; FoMoCo "Blue Spring" upgrade; Galaxy DX959, Astatic mic & Wilson 1K; Edge Insight CTS; ARP head studs, FoMoCo head gaskets, FoMoCo oil cooler, EGR delete, HPOP, IPR; HFCM Updated Drain Plug;
To Do: ISSPRO Fuel Pressure Gauge, R&R all suspension bushings, Preventative Maintenance
I put mine on today and I ended up grinding the U shape(that goes under the grommet) deeper, so the bracket goes up higher. My filter would have been sitting on top of the a/c line if I didn't grind it deeper.
Anybody know why the bracket that holds the filter & housing on is so big and extends the filter away from the radiator? I don't have very much room to get the filter on/off. I had to take the filter housing off to get the filter on, then bolted the housing back onto the bracket.
