Just took delivery of my 1st 6.0! - Diesel Forum - TheDieselStop.com
Old 08-21-2006, 11:23 PM   #1 (permalink)
Hey guys. As stated above I traded in 2 7.3's on an '07 F550 4x4 chassis/cab. Right now it's getting fitted for a dump box. What is the break-in procedure for these 6.0's? Mileage of first oil change? I've been running 15w40 Rotella for 14 years. Do the '07 6.0's like it? I'm sure I'll have many more questions but, for now what do you think? Thanks in advance. Eric
2008 Chev 2500HD CC SB LTZ 4X4 Duramax/Allison, dual alternators, B&W Turnover ball w/ Companion, 8'2" Boss V-plow, Timbrens
SOLD----2002 F350 CC SB, 4x4, Lariat, leveling kit, 285 BFG's, AIS w/ fender sleeve, AIC, A-pillar Pyro, Boost, Trans, SCMT, 4" Magnaflow turbo-back, AIH delete, Weatherguard toolbox, 8'2" Boss V-plow, Hide-a-way strobes, B & W Turnover Ball and Fifth Wheel Companion, Fumoto, 203* Stat, Bilsteins, XM, C-Betrs, 136,000 miles,Hella 500's up front, Hella flush mount back-up lights, Speed Bleeders, Air Lift rear bags w/ inside controller
Pulling this:
2005 Alumascape 35 FLQ by Holiday Rambler w/ 5 slides
2007 F550 4x4 XLT, 11' contractor dump box, dual alternators, Tow Command, Upfitters, C-Betrs, #19000 GVW, Fumoto, 9'2" Boss V-Plow, 8' V-box salt/sander, LED flashers
prograde is offline
Old 08-22-2006, 02:15 PM   #2 (permalink)
Re: Just took delivery of my 1st 6.0!
Should be a sweet ride.
Let's not start another oil debate though....
Change it per the book with whatever you feel comfortable with so long as it has the proper rating.
'06 F350 CC Red 4X4 Lariat auto
rickeg is offline
Old 08-22-2006, 03:25 PM   #3 (permalink)
I'm a Rotella guy myself, and have had good results in my 2004 6.0. My granddad was a Rotella guy, and my dad was too. It's an International Engine after all, so I don't buy the "Only Ford Oil with work". As far as filters, I get them from the local International Dealer, for my oil and fuel filters, and they're a good bit cheaper.
2004 F-350 Lariat SRW <><
315 BFGs, Edge Platinum, ARP Studs, & B&W Goose
1998 Cherokee RockCrawler
NCfarmboy is offline
Old 08-22-2006, 05:14 PM   #4 (permalink)
Oh come on! The whole world knows that the best oil is Ams...
Seriously, congrats on the new ride. Stick with Rotella since you've had good luck with it for so long. Just change as recommended in the manual and you should be fine.
2005 Arizona Beige F350 XLT FX4 6.0 CC shortbed, 3.73 ls rear, 18" wheels, Tow Command. Additions: Vent Visors, bug guard, Fumoto Valve, Timbrens. Traded for...
Current Truck -- 2008 Black F350 XLT 4x4, 6.8 V10, CC Long Bed, 4.10 rear, 18" wheels, IBC. Additions: Chrome Step Bars, Chrome door handles, Silver barbed-wire pin stripe, B&W Turnover GN ball
barrelhorses is offline
Old 08-22-2006, 11:06 PM   #5 (permalink)
Thanks guys. The owners manual was in the truck at the upfitters so I could not ref. it. So I'll stick with 15w40 Rotella in summer and 10w30 Rotella in the winter. This truck will weigh about 10500lbs with an empty dump box and pulling about 13500lbs worth of trailer. Should I go with the severe duty recommendation of GOF every 5000 miles? Or less? At what mileage should I do the first oil change? Man I can't wait to drive this truck. Speaking of debates it's been kinda slow on the antifreeze debate. Eric
Pulling this:
prograde is offline
Old 08-23-2006, 04:55 AM   #6 (permalink)
Just my .02, but I'd change oil at 5K intervals. That's what I do anyhow. Since your truck is a dump truck, it will be working hard. You can't go wrong by giving it fresh blood a little more often.
Old 08-23-2006, 08:58 AM   #7 (permalink)
Should I run it to 5000 miles for it's first oil change or do it sooner. Eric
Pulling this:
prograde is offline
Old 08-23-2006, 09:01 AM   #8 (permalink)
I had mine done at 3000 because of the motor being brand new. Cheap insurance. I will do 5000 miles between them now.
moldman7n is offline
Old 08-23-2006, 09:08 AM   #9 (permalink)
Thanks for your help. Eric
Pulling this:
prograde is offline
Old 08-23-2006, 11:02 PM   #10 (permalink)
SUPERTuFF1's Avatar
I change the oil in mine every 5K too regardless of what duty I have it performing.
'03 F-350 LRT CC LB SRW FX4
6.0L-Torqueshift-3.73;Eng.Born 6/20/03;114K miles
Husky Floor Liners/ Rhino Bed Liner/ Husky 5th Wheel Hitch/ EGR In-Channel window visors/ X-Springs with Bilstein Shocks/ Airlift System: SuperDuty airbags and Load Controller II/ 18 inch Ford SVT rims on BFG 285/70/18s
SUPERTuFF1 is offline
Old 08-23-2006, 11:30 PM   #11 (permalink)
I would never go the normal recommended mileage before changing out the first oil. I believe it is filled with lighter weight oil when new and it gets dirty pretty fast with all the "stuff" from the break in.
I changed around 2500 for my first change and the guys at Blackstone Labs said that most Powerstroke owners wait entirely too long to change out the original oil and that it was good that I had done it as it starts out light and sheers pretty fast in these engines. My engine continues to show good wear patterns with no problems.
With you using the truck as you do I wouldn't go over about 4000 even though they recommend 5000 now. Yours would be considered severe duty use.
Heck I was so used to changing at 3000 on all my previous trucks that it took several oil analysis and Blackstone telling me I still had several thousand miles life left in the oil when I changed it before I was convinced I could go 5000. Of course mine is not used for work like yours will be.
Delivered 3/2/04--2004 F350 XLT 4X4 6.0L PSD 5sp Auto CC LWB DRW /Oxford White/MedParchment/4.10LS/ ESOF/Skid Plates/Sliding Rear Window/ Privacy Glass/BSW A/T /Tele TT Mir-Pwr/Fog Lamps/
Autometer Cobalt 3 gauge A-Pillar/15k Hitch/ Prem AM FM Cass CD/ UWS Deep ToolBox/Line-X Waag Kick-out bars/Line-x/Custom Flow Tailgate.
Pulling a 2004 Forest River Spinnaker 29WBLE 5ver.
I'm Towing Now!!!!!!!!!!!!!!!!!
earnhardtfan55 is offline
Old 08-23-2006, 11:41 PM   #12 (permalink)
Thanks I know what you mean when it took you a long time to be convinced to go more than 3000 miles on an oil change. Same here. I have trouble going to 4000 miles right now. The thought of going to 5, 6, or 7500 miles is insane. I'll stick with 4000 and do the first change early. Thanks for your input. Eric
Pulling this:
prograde is offline
Old 08-24-2006, 08:48 AM   #13 (permalink)
Not really. The Cummins is rated at 15k between changes. Severe duty schedule drops that to 7500 miles. Class 8 big trucks go 25k between changes under most schedules. I change mine every 6k.
2003 Ram 3500, DRW, Cummins HO 48re 4.10...loaded.
i6DZUL is offline
