Keeping my 6.0 stock - Page 2 - Diesel Forum - TheDieselStop.com
Old 03-27-2009, 04:53 PM   #16 (permalink)
GiraffeCat's Avatar
Originally Posted by OMCUSNR View Post
Sorry, This is NOT TRUE! Removal or tampering with an installed emissions device is a violation of the FEDERAL Clean Air Act, and if you take the cat out, you LEGALLY have a vehicle that can only be used at the drag strip, a tractor pull or on a farm or private ranch. You cannot legally register it for use on a public road, street or highway.
HOWEVER, enforcement is up to each state, and is lax or non-existent in most states, except California, where its about to get stiffer.
OMC
Well, Okay if you want to get picky, then any modification to any point in engine operation or control is a violation of emissions rules! That means anything! Reflashing ECM / TCM is illegal, intake, exhaust, egr deletes, block off plates, and so on are ALL illegal. ECM/TCM are emissions control devices by design - any modification is a violation (unless done by manufacturer to address control issues). They build the truck and it "passes" the tests the way it is assembled. Same thing with replacement parts - if the vehicle has not undergone crash testing with those components then the vehicle is not in compliance with law! Lift kits, bumpers, wheels, etc. all change the properties of a vehicle in a crash! As you were quick to point out though - enforcement is up to local authorities! So if you don't care about warranty issues, and don't have emissions testing or tree hugger issues - then just forget the cat if you want to!
GC
GiraffeCat is offline
