I have a 3-4 gallons of kerosine left over from a couple of heaters I use in my barn. Won't be needing them until next winter, and didn't think I'd want to use the old kerosine after such a time, so is it OK to burn this stuff in my 6.0?
Should be about the same stuff as #1 diesel ? Didn't know about the lubrication properties of kerosine and if that would make any diff.
AutoJim
Former Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
'97 Dodge Neon, SCCA ITA/STU/EP Club Racing
Is it dyed red (signifies no road taxes were paid on it)? Admittedly, you're only escaping about a buck of taxes by burning it, but if they just happened to dip your tank at the wrong time, it's going to create a whole bunch more than a buck's worth of headache for you!
Duncan
The 1997 F250HD Crewcab: Picture
The 2000 XLT Excursion <font color="red">(SOLD)</font>: Picture
The 2003 F250 Crewcab 6.0L: Web page
The 6.0L Bible: Web page
The 6.4L Bible: Web page
Winter grade fuels have as much as 20% kerosene. As long as the fuel is clean I see no problem. Be advised that kero does not have as many BTU's as diesel and would adversely affect your fuel mileage. Not much, but some
2005 F-250 Torque shift, Hypermax programmer and 5" exhaust 140,000 almost trouble free miles
The lubricity of kerosene is not the same as diesel. You would be risking your injectors inless you ran it with a lubricity enhancer or alongside regular diesel. Even then, its not ment to be used in the truck, so why use it to save a couple pennys. Unless I was out of diesel in the middle of a desert with nothing but kerosene, I would never even chance it.
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
AVIC-Z2 In-Dash Navigation System
205cc Elite Sticks
Coolant Filter
Elite Regulated Return Fuel System
FS2500 Oil Filter
HPOP STC Replaced
A little perspective here perhaps? No dye and 3-4 gallons total? Go ahead and mix it two gallons at a time at fillup time. Won't affect lubricity enough to matter and yes, kerosene is about the same as #1D.
You're probably getting a higher percentage than that in winter blend anyway. If still in doubt, just add some Stanadyne PF, which I use in every tank anyway.
'05 F-350 PSD 4x4 CC SB SRW Manual
All of these great "go ahead" quotes from people who don't own the vehicle. Let's say just for S&G that you add the kerosene, but you DON'T add it at the "right" mixture and something happens to your engine, injectors, etc. Are all of these "experts" on this board going to pay for your repairs that aren't covered under warranty. Insead of "burning" 2 dollars worth of kerosene in your Ford, why not sell it to these "experts" in their rigs so if something happens it's on them? All this nonsense to "save" a few bucks....really!!
2004 F350 Crew XLT 4x4 long box, SRW, 3.73 Gears
Bone Stock
If we were talking used motor oil, or brake fluid, or ATF, or any number of other odd oily substances, I could see your point. But this is kerosene for goodness sake! It's a fuel. It's like "diesel lite." It's commonly blended with diesel, at much higher percentages than is being discussed here, precisely to thin it out and lower the gel point in extreme cold. The only possible downside is reduced lubricity, for which there are numerous fine products to counteract, just like a lot of people do when running winter blend fuel anyway.
Seems like burning it in the truck is a perfectly legitimate way to get rid of it, even with the additional cost of a bottle of additive. I believe the original poster was looking for a way to sanely get rid of some leftover kerosene (as opposed to say, dumping it down the sewer), not as a way to save a few bucks, and this is a great way to do it.
Duncan
Thank you, a few gallons will not hurt. If engine was "worked" and taken to track and run WOT it "might" hurt the injectors. I would like to meet the man that could prove the kero caused the problem.
To add a little more perspective to this issue, Ford's additive is more than 60% Kerosene and up to 10% Naptha. MSDS HERE
The choice whether to burn it in your truck is yours to make, but if it is clean there should be no issues connected with mixing it into the tank a bit at a time.
2003 F250 XLT Sport Ext Cab ESOF FX4 6.0L TorqShift, Sonic Blue/Black Leather.
BrakeSmart Trailer Brake controller.
Leer Cab high Browning Edition Cap.
2004 SunnyBrook Solanta 28' TT small slide 7800#
35 Years in the trenches!
Retired Machinist & Manufacturing Engineer for fuel control systems for very large Diesel Engines. Locomotives to Super Tankers.
Designed and trouble shot manufacturing processes for stuff from Design Engineers. Sometimes had to wrestle for design changes.
Designed and built tools and equipment to machine, assemble, disassemble, repair and test.
Wisdom comes with age, but sometimes age comes alone.
"Nothing is FOOLPROOF because fools are too ingenious"-Mark Twain
