Latest fuel economy update - Diesel Forum - TheDieselStop.com
Old 06-30-2009, 07:11 PM   #1 (permalink)
Just completed a 2,800 mile round trip from southeast Pennsylvania to Voyageur National Park in Minnesota, and back. Averaged 16 mpg, hauling a 3,500 lb boat, with four in the cab. Speed was in the range of 65 mph - 70 mph. Truck has 142,000 miles on it. Terrain was mostly flat except for the ridge and valley province of Penna.
Mileage was hand calculated and fuel was filled to the top of the neck.
Truck ran well. Had good weather and fun times, but experienced tons of biting gnats and the fishing on Crane Lake was far below expectations.
2003 F-250 XLT CC SB 6.0L 6sp 2WD 3.73 open diff, cab lights, 6 disc, camper pkg, spare tire, sliding rr wdo, hitch rcvr, lighted TTT mirrors, security group, black/silver, ordered 12/17/02, built 2/13/03 13:56, delivered 2/19/03
2004 Cardinal T31BH travel trailer
1997 Lund 1700 Pro Sport, red over tan, 90HP Honda 4 stroke, 9.9HP Honda 4 stroke, 40 lb. Minn Kota bow mount
chassis is offline
Old 06-30-2009, 07:23 PM   #2 (permalink)
kys03rigger's Avatar
I get about the same with same load. Maybe 14 if I get it above 70. Much better than my 7.3.
2005 250SC FX4 6.0L 3.73's, ARP Head studs, '03 Turbo, '07 turbo drain tube, AFE PRO Stage 3, Edge Insight; MBRP Turbo back cool duals, SCT X3 Programmer with my custom tune, CFM Carbon Fiber Inlet, coolant filter, Boss 8' Pro Poly, Wheelen hide-a-way strobes, Sho-me LED's.
kys03rigger is offline
Old 06-30-2009, 09:11 PM   #3 (permalink)
Strokin' 6.0's Avatar
You guys suck! I'm lucky to get 16.2MPGs empty, 12MPGs with our 31' Airstream and 10.4MPGs with our 26' steel Thoroughbred trailer.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
Old 06-30-2009, 09:28 PM   #4 (permalink)
EBX
EBX's Avatar
My Photos: (6)
I get 13 pulling my 10K camper and 20.2 unloaded.
'03 Eddie Bauer, Excursion 6.0 PSD (Bought New) & (All Stock), 4WD, 3:73 Limited Slip. 6.0 build date March '03, Premier group, video pkg, roof-rack (lighted), 3 pillar pod, Timbrens-on back.
I change oil every 5k (Rotella Syn. 5W-40), fuel filters every 10k (Ford Filters Only), air filter every 30K (Ford Filter Only), Changed trans. oil/filter & diffs. oils at 50K. Mostly highway miles & some around town.
From 5/23/09 - 6/19/09 At 62K miles & 9 months out of warranty, I spent $8K b/c of & getting this X fixed; 3 Ford Dealers in 3 dif. states replaced: EGR Valve, Cleaned Turbo Pipes, IAT,Map Sensor, ICP, VGT, (Cleaned Turbo -Compression ring still sticking), Replaced Turbo. On 6/19/09 I bought Ford Ext. War. 4yrs./48k.
Buy your Ford Factory Ext. Warranty.
EBX is offline
Old 06-30-2009, 09:40 PM   #5 (permalink)
I get 18.4 running from SE Pa. to the middle of the state through the rolling hills empty. On the level highway I get around 20.1 empty.
Ljutic SS is offline
