Anyone know where to find the latest TSB for Head Bolt Torque Sequence? I have the original from 02/03 however I’ve heard it has been updated since then. By the way this will be for installing studs…
Okay folks, since nobody wanted to touch this one here are the recomendations from ARP for their studs...
ARP...
Tighten the head bolts in the following sequence.
Tighten bolts 1 through 10 to 65 lb-ft.
Tighten bolts 1 through 10 to 100 lb-ft.
Tighten bolts 1 through 10 to 150 lb-ft.
Tighten bolts 1 through 10 to 200 lb-ft.
Tighten bolts 1 through 10 to 245 lb-ft.
Tighten bolts 11 through 15 to 24 Nm (18 lb-ft).
Tighten bolts 11 through 15 to 31 Nm (23 lb-ft).
I've also attached the latest updated bolt sequence & torque values for Ford's TTY Bolts from the Ford Shop Manual... Hope this helps everyone...:thumbsup:
Campingtom, I’m only a couple of hours away so let me know if you need any help…:thumbsup: Plus I got family north & south of you that I can send the wife and kido's to.:jester: My new heads arrived yesterday and the black-o gaskets should be here today so going to be an eventful weekend.
JR
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
