Latest TSB for Head Bolt Torque Sequence??? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 01-18-2010, 11:34 PM Thread Starter
joshr33's Avatar
Anyone know where to find the latest TSB for Head Bolt Torque Sequence? I have the original from 02/03 however Iíve heard it has been updated since then. By the way this will be for installing studsÖ
Thanks,
JR
joshr33 is offline
post #2 of 5 (permalink) Old 01-20-2010, 03:28 PM Thread Starter
joshr33's Avatar
Okay folks, since nobody wanted to touch this one here are the recomendations from ARP for their studs...
ARP...
Tighten the head bolts in the following sequence.
Tighten bolts 1 through 10 to 65 lb-ft.
Tighten bolts 1 through 10 to 100 lb-ft.
Tighten bolts 1 through 10 to 150 lb-ft.
Tighten bolts 1 through 10 to 200 lb-ft.
Tighten bolts 1 through 10 to 245 lb-ft.
Tighten bolts 11 through 15 to 24 Nm (18 lb-ft).
Tighten bolts 11 through 15 to 31 Nm (23 lb-ft).
I've also attached the latest updated bolt sequence & torque values for Ford's TTY Bolts from the Ford Shop Manual... Hope this helps everyone...
JR
joshr33 is offline
post #3 of 5 (permalink) Old 01-20-2010, 04:54 PM
aekrogh's Avatar
good post. thanks.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
post #4 of 5 (permalink) Old 01-21-2010, 01:07 PM
CAMPINGTOM's Avatar
Yeah, thanks. May be I can convince you to come over to W. Florida when I'm ready to do mine.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, Sinister EGR, Insight Monitor, SCT X3 (Tuned by Innovative)
Blue Spring, Atlas 40 FICM Tune
CAMPINGTOM is offline
post #5 of 5 (permalink) Old 01-21-2010, 01:44 PM Thread Starter
joshr33's Avatar
Campingtom, Iím only a couple of hours away so let me know if you need any helpÖ Plus I got family north & south of you that I can send the wife and kido's to. My new heads arrived yesterday and the black-o gaskets should be here today so going to be an eventful weekend.
JR
joshr33 is offline
