Lets see how smart you all are. Runs rough when warm? - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 10-20-2011, 08:59 PM Thread Starter
'03 6.0 Powerstroke. Rough idle AFTER it warms up. Runs fine cold. It seems to studder and miss at mid range acceleration. Egr deleted and new oil cooler installed. New lift pump. Replaced ICP sensor. Have 48.5 volts at the FICM. Replaced the fuel pressure spring to the blue one. All new filters. Does not smoke. Does not throw codes. I need to fix this truck one last time. It has a date with the bottem of a very deep lake! It has been nothing but a pos since it hit the ripe old age of 25k miles!
memarkers is offline
post #2 of 15 (permalink) Old 10-20-2011, 09:33 PM
DMC
Are fuel filters OEM?
DMC is offline
post #3 of 15 (permalink) Old 10-20-2011, 09:37 PM
Need to look at ICP, ICP desired, and IPR duty cycle readings at various rpms.
What are you using to read codes?
Mark
bismic is offline
post #4 of 15 (permalink) Old 10-21-2011, 09:11 AM Thread Starter
OEM filters for sure. As far as the code reader it is a loaner from a buddy. Not real sure of the brand. I'm not getting the CEL though. It just blows me away that it runs good when cold but not hot. I can't find one other post anywhere with that being the case.
post #5 of 15 (permalink) Old 10-21-2011, 10:17 AM
if you could get a scanguage from somebody, check out the icp sensor and the pressures at various while running.
05 f250 6.0 xlt ext. cab long box Fx4, 130k auto, 3.73's, stainless along bottom, 105 gallon L-shaped fuel tank, 8'6" Boss poly v-plow, 2 cracked y pipes, replaced egr valve, replaced ficm, 2 new napa batteries, new ford 140amp alternator, blue spring upgrade, scanguage II, sinister cooant filtration system, drivers side ball joints at 130k, retired juice w/ attitude on the shelf
**to do list**
egr delete, programmer, egt and fp gauge, coolant flush with elc, 5" turbo back
99 f250 5.4 xlt reg cab long box 4x4 5pd manual, 125K, 4.10s, L-shaped fuel tank, shot one plug
11 f150 King ranch 4x4 3.53s, CC 5.0 6sp, 2 tone white/tan, everything but tailgate step
Joe_r_dog is offline
post #6 of 15 (permalink) Old 10-21-2011, 01:35 PM Thread Starter
are you talking about the scangauge II?
post #7 of 15 (permalink) Old 10-21-2011, 01:41 PM
yes or a edge insight.
thats how smart we are
05harley is offline
post #8 of 15 (permalink) Old 10-21-2011, 07:31 PM
You may want to check/replace the check valves on the oil rails. When the check valve/valves fail, it will cause a rough run at the 1700 to 2400 rpm range (if I remember correctly). Would definitely recommend checking for codes with ford specific scan tool.
djshum is offline
post #9 of 15 (permalink) Old 10-21-2011, 10:19 PM
Just curious, are you still running the egr throttle plate on it? Do you have delayed shifts as well? b
03 F-250 CC LB XLT 3:73 rear/ almost stock/ early build/ 78,000 miles...03 F-250 ext cab Lariat Fx4 SB 3:73's /stock/187,000 all original injectors...FICM by Ed @FICM.COM / ScanGuage 2 monitoring the vitals...
03powerstrokeuser is offline
post #10 of 15 (permalink) Old 10-21-2011, 10:41 PM
bigb's Avatar
What kind of oil are you running and how fresh is it?
Brian, Tucson, Arizona
02 F350 4x4 CREW 7.3 160K, BFG Rugged Terrain 285s, AIS, Isspro pyro, boost & tranny temp pillar pod, Dipricol coolant temp, ELC, Isspro EV-2 Fuel Pressure & HPOP, Dieselsite boots, coolant & tranny filters & 203* Stat, 6.0 Tranny Cooler, ITP pre pump tank mod, Bellowed Up Pipes, Riffraff Frx, netbook mount with AE, GPR LED, Stancor, Red Head steering gear, Battery Tender & 2 Marincos.
bigb is offline
post #11 of 15 (permalink) Old 10-21-2011, 11:32 PM
spinninall4's Avatar
i would do more testing but i suspect Ipr Valve i had a similar issue you wouldn't feel it cold only hot and at a steady speed it felt like it was missing and surging no codes or CEL changed ipr all good!
2005 F-350 Fx4-Lariat 6.0l, ARP Headstuds, RCD D-Kit, Banks Turbo back 4" duals, Banks Test Pipe, AFE stage2 intake, dfuser Coolant Filter, High Idle, SCT Touch Screen with Custom Tunes by Vivian@quicktricks,190cc/75% Injectors, HD Headlights with HID 8000k Bulbs, Rhino Box Liner, A.R Tactic Matte BLK 18" Rims wrapped in 33x12.5 Toyo Open Country, 2.5" Ranco Leveling kit, RS9000 Adjustable Shocks, 240Amp Alt, Alpine CDA-9887,2 Alpine Type X 10" Powered by PDX 1,1000 RMS, Alpine Type R 5x7 Powered by MRP-F600
spinninall4 is offline
post #12 of 15 (permalink) Old 10-22-2011, 08:36 AM Thread Starter
03powerstrokeuser, yes to both questions. I dont get the delay until after it's warm and starts acting up. Can the truck be throwing codes without the CEL on? The reader I've been using always shows the codes when the CEL is on but right now It's just not on. I changed the oil yesterday (T6)and added HSS just to give it a try. The shop that sold it to me said at the very least it will clean the truck out so why not.
post #13 of 15 (permalink) Old 10-22-2011, 11:15 AM Thread Starter
It may be the IPR. I have no way to test it. Its going to the shop. I give up! I'm $700 in at this point. Besides, the guys at the shop need to make a living too! This is the last straw. Shes going on the auction block when I get it back!
post #14 of 15 (permalink) Old 10-22-2011, 12:42 PM
[QUOTE=memarkers;2122293]It may be the IPR. I have no way to test it. Its going to the shop. I give up! I'm $700 in at this point. Besides, the guys at the shop need to make a living too! This is the last straw. Shes going on the auction block when I get it back![/QU
What is the manufacturer of the scanner?? scan gauge ?? edge insight ??
either one of these will pick up a code. i know mine does.
I think if i would buy another scanner it might be the autoenginuity instead of the edge insight for the money.Or if i could use it to its capability. That is why everyone here is preaching the gauges to eliminate other problems that has same causes or similar issues,instead of throwing money at it. the $700 that you paid already might of bought.both the repair and a gauge.
just my .02
05harley is offline
post #15 of 15 (permalink) Old 11-20-2014, 07:51 PM
was the problem ever figured out?
nlouison is offline
