Lie -O-Meter - Page 2 - Diesel Forum - TheDieselStop.com
Old 09-22-2005, 07:49 PM   #16 (permalink)
Re: Lie -O-Meter
Yeah, I keep a floor jack with me at all times so I can jack it up at the pump and get that last gallon in it.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
Old 09-23-2005, 12:42 PM   #17 (permalink)
Re: Lie -O-Meter
Shooter, just to make sure. The two buttons on the trip computer on your overhead console need to be pressed at the same time to reset the MPG reading. You can reset it anytime. I usually reset the overhead and my trip odometer at every fill up. The 'miles to empty' changes based on how much fuel is in the tank and the current fuel consumption. Resetting the MPG calc may or may not affect the 'miles to empty'.
Sometimes I will reset the overhead on the highway to get an idea what MPG I am currently getting. If you do that tho, you have to realize that what it reads and what you might hand calculate on your next fill-up will likely not match.
2004 Excursion Limited, Black, 4x4, 6.0L, Hellwig 30 mm Rear Antisway, V Codes & Modified B Codes, Rancho RSX's, MRBP Turbo back, AFE Intake, Quadzilla XZT
Sam Eaton
Dallas, TX
TxSam is offline
Old 09-23-2005, 12:51 PM   #18 (permalink)
Re: Lie -O-Meter
Just did my first hand calculated MPG estimate today. My math indicates 14.4 MPG. Onboard computer estimates 14.7 for same tank of fuel (reset at each fill up). I'd say that's close enough to be useful.
2005 (Built 07/04) F-250 6.0L PSD Lariat/SRW/CC/4x4.
(Almost Stock: SEIC, Oil Bypass, Coolant Bypass,...)
ShotWho is offline
Old 09-23-2005, 01:33 PM   #19 (permalink)
Re: Lie -O-Meter
I reset at every fill-up, and hand calc all mileage, filled to the neck. My lie-o-meter has been consistentally optimistic by 1-2.5 mpg since new. Truck has stock wheels and tires, so no error there!( Could be the Edge, ya think!!) I like looking at what it says; makes me feel better about the mileage I'm getting(till I fill up again!!) C-Ya!! [img]/ubbthreads/images/graemlins/tongue.gif[/img]
2005 F-350 DRW CC,4x4,LB,Lariat, 6.0 PSD, True Blue Metallic, Magnaflow exhaust, kitty went home, SS running boards, Lund deflector, Husky FW tailgate, Rancho RS9000's, JBL amp, MB Quart speakers, Pioneer 12" sub, and a billet aluminum antenna!!
MCR500 is offline
Old 09-24-2005, 03:30 AM   #20 (permalink)
Ned
Ned's Avatar
Re: Lie -O-Meter
It may be silly , But I usually tap it (reset it ) often while driving down the road to see if I'm at a good speed for economy.
It will start out high and usually drop.
2000+/- RPM is the best it seems. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
'04/'04,PSD,TS,SRW,Ox.White,F350,CC,LWB,Lariat,Fx4,Cam per pack,Built 12-16-03.
Mods.
X-springs,Bilsteins,insulation blanket,Velvet Ride shackles , muffler delete Pulls a Raptor 5erTruck
Ned is offline
Old 09-24-2005, 09:44 AM   #21 (permalink)
Supporting Member
andrewbalser's Avatar
Re: Lie -O-Meter
I fill mine "to the brim" on every fillup. I forced myself to be conservative last week and not drive over 55, and kept my RPMS below 2000 for a whole tank. Not that it would be bearable to do this all the time, but my '03 gladfully reported 20.9 mpg, and my hand calculation was about 20.4. It was the first (and maybe the last) time my trip odo ever even made it in the 600's on the same tank of fuel. For those of you who are new or unfamiliar to the trip computer, the mpg/Lp100K can be reset by pressing both buttons at once. The distance to empty is calculated using the current position of the fuel level sensor, but the usage rate of the previous fillup applies. If you begin towing a heavy load you'll notice the mpg will drop, but the distance to empty does not immediately adjust. That's because the distance to empty uses the rate acheived from the previous fillup, however, as the fuel level sensor drops, the distance to empty will adjust(sometimes rapidly). Therefore, in a condition such as the one mentioned above, the distance to empty will be swing back and forth from very inaccurate, to more accurate during different periods of the usage of that fill.
Please note, I did not read this in a book, or manual. This is merely a theory that I formed from very closely analyzing the readings, and my driving situation.
2003 RED F-250 Lariat FX4
SuperCab, Short Box, 6.0L, Torqueshift
"1991" Sun-Lite Pop/Up Slide-In Camper
DIY-Coolant Filter
137,000 as of 1/26/2012
3/19/11, Converted to (red) Delo ELC, new bottle & cap, all temps reading good, orig EGR & OIL coolers, probably thanks to the coolant filter, and previously frequently flushed Motorcrap Gold.
Keep on truckin
andrewbalser is offline
Old 09-24-2005, 02:05 PM   #22 (permalink)
Re: Lie -O-Meter
I never reset mine and it reads 18 with the AC on and 18.1 with the AC off, hand calced is 16.754, filling to overflow everytime. What I have noticed is that the lie-o-meter doesn't take into consideration the AC load. If I drive a whole tank with the climate control OFF I get 17.75 while the meter says 18.1. Interesting that the AC takes 1 mpg.
rhonamitra is offline
Old 09-26-2005, 07:27 AM   #23 (permalink)
Re: Lie -O-Meter
I fyou never reset yours then it is averaging your fuel usage for the entire time you have had your truck....
and therefore you can't tell the diff from one tank to the next....
sorta like a batting average....
1 hit for 5 at bats is a 200 batting avg...
get one more hit and you are now at
2 hits for 6 which is 333...... a BIG change...
but say you have a 200 batting avg at 1000 at bats...
200 hits for 1000 and you get one more hit...
your batting average doesn't really change - just to 200.8 [img]/ubbthreads/images/graemlins/smile.gif[/img]
JohnBoyII is offline
Old 09-26-2005, 09:02 PM   #24 (permalink)
Re: Lie -O-Meter
Instead of calling it a lie-o-meter---why don't you just turn it off-----jeesh--all the extras just make people more picky-----what did you do 15 years ago when we all had manual locks and windows and no fuel mileage meter------get real!!!!!!!
Supercrew [img]/ubbthreads/images/graemlins/smokin.gif[/img]
p.s. not directed at bigred at all---but to the thread starter
[/ QUOTE ]I've got an 05 with manual locks and windows [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img]
'05 single cab f-450,10ft stake bed
'00,SprCb,DRW,6spd. 190k Garrett BB Turbo, AFE stage II, LUK clutch w/kevlar bearing, intake heater delete, acetone badges...
I10haulR is offline
Old 09-27-2005, 12:23 AM   #25 (permalink)
Re: Lie -O-Meter
Don't know for sure about 2005 and up, but the 2004 "Seeds" ,per the manual, the AVG MPG with 500 miles on the last tank when you do a reset. In other words it is doing a 2 tank average. 29 gallon or 38 gallon tank gets the same "Seed". Left my 2004 without a reset for many refills and the numbers started hitting the nose. At 20,000 miles a difference of 0.06 MPG.
EDWARD
EDWARDWD is offline
Old 09-27-2005, 12:43 AM   #26 (permalink)
Re: Lie -O-Meter
I applaud you------some people tend to forget what it was like without all these creature comforts-----I just look at it as more crap to BREAK. I admit, I own a Lariat----but I definitely don't depend on all this stuff to tell me my mileage per gallon. It is just a quick reference while driving---not true to life---I work for a cadillac dealership as a master technician, even the CADILLAC ones are not 100% dead nuts on. Just a estimate round average-----
Supercrew
2004 F250 Crewcab PSD FX4 Lariat--Oxford White--18" Stock wheels--Loaded--Grey leather--Bedliner--Chrome fender flares--3.73 rear end--6/21/04 build date--Custom Harley Flames just added!!
My other rides.....
2002 F150 XLT Supercrew, FX4 5.4l all stock
2001 F150 Lariat Supercrew 2wd 5,4l all stock
1995 Saturn SC1 SOHC 4 cyl.
1993 GMC Safari XT 4.3l 6 cyl.
1968 Chevy Camaro w/1989 Corvette 350 w 700r4 trans w/overdrive, Holley demon carb, mostly original.
2002 Wanderer Glidelite TT w/slideouts 26ft.
1974 Reinell Tri-hull openbow 165 horse OMC.
Cadillac Technician-A.S.E. Master and GM Master
Supercrew632 is offline
Old 09-27-2005, 05:15 PM   #27 (permalink)
Re: Lie -O-Meter
the readout in my 2003 was a real piece of junk,, only good for the temperature,,
new 2005 has been within about 2 tenths for the first 10,000 miles for city and highway,,
have quit checking the mileage with the calculator as the .2 is close enough for me,,
2005 F350 KR, 6.0 SRW, Crew Cab, 72 gallon fuel, Centramatic balancers,,
Fifthwheel2 is offline
Old 09-27-2005, 08:58 PM   #28 (permalink)
My Photos: (23)
Re: Lie -O-Meter
The one in my 03 7.3 was almost dead on, + or - .3. My 04 6.0 can be anywhere from .3 to 1.5 high, it has done better after this latest flash though.
Jim
2004 F-350 Lariat, 6.0/04, Torqshift, Black, CC, SB, SRW, 4X4, FX4, 3.73LS, Moon Roof,Power slididng rear window,Dual alt.,Adj. pedals,Heated seats, in dash 6 CD changer,hood blanket,ARE Z-series camper shell,Fumoto valve,Schaeffers 9000 series 5W-40,Zanos polish. Ordered on 11-21-03, Built 3-8-04, picked up on 3-25-04.
jwillett is offline
Old 09-27-2005, 11:53 PM   #29 (permalink)
Re: Lie -O-Meter
After hand calculating and determining what % the difference is, get a good programer and get them to Recalibrate the fuel computer, thru software...
Problem solved
Or you could do like everyone else and recal in your head.
Its up to you.
2000 F250 SC 4A SB OEM TC, OEM Trans, OEM Turbo, OEM Injectors, OEM Airbox, OEM CAC, Quad Pod W/4 Autometers, 3 Guage cubby-hole, Jody-isized, Fuel System Mods, Mag Hy-Tec, Schaefers 9000, Transgo, Interior is soundproofed, 3.5" DP SS XL Magnaflow, LPG, 106k miles, NVK5 to MNMO, 2200 WATT BI-AMP, 18"s, Best MPG-22.80, Best MPT-760 miles.
FORD-DIESEL.COM MODS--Heater Hose Cutoff Valve, T/C lock, EBV brake, MIAH Plug, QD's removed, Wrapped CAC Tubes, Double Clamped Coolant Hoses, Zoodad, Relocated License plate, painless fuse box. Other RSB Mods
388HP 818Ft.Lbs.@ 130MPH. 4th gear dyno run, 2.1 60, Home-Made Traction bars.
This is a Street truck, 18+MPG(No LP), 14.2 at 98mph, 13 sec Motor, 14 sec Truck(NO Traction)
2004/03 CC SB Auto 6L W/OCT flash, 19+MPG, 20%Bio, AFE, Magnaflow XL SS 4" Exhaust, 75K, Heater By-pass mod, 21.1 MPG best.
2006.5 Jetta DSG 14K 41MPG Best
2005.5 VW Jetta 1.9 TDI 49MPG Best 73K
Kubota 7800 30 HP Hydrostatic 4X4
All Diesels
1969 Mach1 351C 4M 9"
Mach1 is offline
Old 09-28-2005, 12:57 AM   #30 (permalink)
Re: Lie -O-Meter
TXSam,
Just to clear something up, on Shooters1380's truck in his profile he has an 05 King Ranch. I don't believe he has the buttons on the overhead console to reset. I know on my 02 Lariat I could push them both on the roof to reset the mpg. On my '06 King Ranch, it automatically resets the average mpg when you refill. (It is built into the dash because I have the sunroof) I believe that is why he was asking the question about resetting it. I'm not sure he can - it does it automatically. You can reset the trip - but that is it. Someone please correct me if I'm wrong.
Ken
'06 F-250 4x4 King Ranch CC/SB Diesel. True Blue/Arizona Beige
kenv is offline
