mlsteele, if your transmission behaves the way my 4R100 behaves, you might try this if you're ever in a similar situation again.
Try starting out in 2nd gear instead of drive. At least in the 4R100, the truck actually starts out in 2nd gear if you put it into 2, so you aren't slipping the wheels as much as you would with the low gear of 1st gear. I''ve got 2wd, and LS, and the LS has left me stuck in my yard and stuck in a ditch before. I started using 2nd gear instead of D or 1st gear to get the truck moving, and I haven't gotten stuck since.
I don't know if they improved the LS in the later model superdutys or not, but for the earlier ones (99-2001), the LS was (and still is) a joke. jst my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Access bed cover, Bed Rug, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, 103K somewhat error-free miles (so far) [never back to dealer for anything]
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2), driver door pwrlock actuator, water pump
2009 VW Tiguan 2.0 l turbo 200 hp gas engine (TDI engine not available for it yet)
