Link to front bearing replacement - Diesel Forum - TheDieselStop.com
Old 06-02-2009, 02:12 PM   #1 (permalink)
I thought I saw a link someone posted with a how to to replace the front bearings on the 4wd trucks. Anyone still have that?
2004 F250 CC FX4 175k miles and counting
reprogrammed egr Innovatives programming
straight piped Airaid intake harpooned tank
hooknline is offline
Old 06-02-2009, 02:29 PM   #2 (permalink)
I did mine (actually just cleaned/repacked them) as part of a ball joint replacement. Just skip the parts that don't apply.
Ball Joint Write-Up
03 F250 SD Crew, Fx4, Lariat-160K
02 F150 XLT Super Cab-135K
07 Toyota Highlander-35K
2Tight is online now
Old 06-02-2009, 04:07 PM   #3 (permalink)
rock_doctor's Avatar
good luck, i don't think i am brave enough to do this but i would imagine you are saving yourself a couple hundred dollars per side.
2005 Excursion w/ 6.0L PSD
2008 FX4 F250 CCSB w/ 6.4L PSD
rock_doctor is offline
Old 06-02-2009, 04:22 PM   #4 (permalink)
The bearings are very expensive (if not replaceable) if you are already doing ball joints but if just doing bearings pull the bubs and stop at step #15 then reverse without pulling the axle and knuckle. Depending on the design of your hub you may need the whole hub assembly. For ball joints, the DIY route saves well over $700 compared to a shop. For bearings only it would save a couple hundred or more. My bearing s were OK and I just repacked them. It doesn't take bravery just force and common sense...I was running low on both the day I did mine.
Old 06-02-2009, 04:31 PM   #5 (permalink)
Darn good write up! Im bookmarking that one, so make sure you dont move it. I havent had to do Ball Joints yet at 175k, but they were done at 40k before I bought the truck because they have the zerks.
I have a sneaking suspicion that my left bearings are on the way out. Thanks!
Old 06-02-2009, 05:49 PM   #6 (permalink)
Go to POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners. It is a video that shows how to replace the bearings.
Hope this helps.
Cody
2007 F250 4x4
6.0 Diesel
60k
Coolant Filter
Edge Insight
steel10 is offline
Old 06-02-2009, 08:44 PM   #7 (permalink)
Ok this video needs to be added to a sticky someplace. I did not realize it was so straight forward. Since I own two 4x4 super-duties this is important to know. Thank you for posting this link.
Old 06-02-2009, 10:06 PM   #8 (permalink)
agreed
Old 10-19-2009, 05:25 PM   #9 (permalink)
Great Video!!!
I'll keep mine stock thanks..
RippingTrends is offline
