Dropped the truck off again for oil leak, lost count but its either the 4th or 5th time. They called my and said its ready, rear main seal again. But they think its the aftermarket exhaust that is causing extra heat and making the seal fail. I asked well what made it fail the first three times and his reply was "we only talking about this time." He refused to help with DSB process. Is this something i can start myself or do I need a dealership to start it? Or anyone in Tampa area that has a helpful dealer. I dont want to bring it to Brandon Ford again because it looks like they tring to lay the ground work for a warranty voiding, which is crap. We all know the aftermarket exhausts run cooler. Thanks in advance.
2003 F350 Lariat 4x4 CC DRW, X Code Front Springs w/Fabtech 3.5" Spring Hangers, 5" rear blocks, MBRP 5" Dual Exhaust (No Cat), Edge Insight CTS, EAS w/ EGT Probe, AIC, Sinister Coolant Filter, Blue Spring Upgrade, Zerex ELC Coolant, Sinister EGR Delete, 6.4 Banjo Bolts, Updated Turbo Drain Tube, Updated Oil Cooler Cover, Updated Oil Feed Tube
I'd tell him there is a much higher probability that inproper diagnosis and/or repair procedures are causing it than aftermarket exhaust. I agree with the last post that if the exhaust had any influence, it would be a reduction in temperatures - I doubt that exhaust temp has much impact at all on crankcase oil temp though.
Good Luck!
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
Aftermarket exhaust making it too hot and failing? Is he serious? How and why doesn't OEM exhaust do it? What's the difference? Don't let him say innsulation, Ford dropped the insulation on the DP in late '03.
Holy cow, for it to get hot enough to make the rear main fail, there shuld be discoporation on metal surfaces around it and you'd be in danger of starting a fire.
Jeez, where do these service people come up with this crap?
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
My dually is being bought back for the same thing, and yes you can go to any dealership and ask for the dsb paperwork and start the process your self.Just keep good records and stay in it for the long haul cos it does take some time. Good luck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
F250 FX4 CC Lariat 01' Sold
F350 Dually FX4 Lariat crew cab 04' Ford Buy Back
New Truck
F350 SRW FX4 CC Lariat Chrome Package 06'
Fabtech 8" lift
King Racing 2.5 Coil Over Shocks Up Front
Deaver 5" Rear Springs With King Racing Shocks In Rear
Airlift Airbags
PPE Power Programmer
Amp Research Power Steps
KMC Hoss 20" Black Rims
Toyo 37" Tires
RBP Turbo Back Exhaust With Muffler Delete
To make sure I know which one to call for my service work....
this one --> Brandon Ford @ (813)246-3673 and this web site where I can email them to set up my appt ? www.brandonford.com/service.htm
Good points, I wish I would have thought of that. I tried my best to bite my tounge because at least they were still willing to work on it and not try to void the warranty. Honestly I was just in shock. I cant believe someone would come up with that idea. Thats exactly why I have not done one other mod to the truck. I wish I had not done the exhaust for it to be even an option for them to blame.
What is the DSB I might need it if they don't fix the oil leak this time. Forth time this time. I had a bush guard put on this year in Florida. It's a wounder they don't say that is what is causing the oil leak. Good luck on your fun with Ford. Don't be supprise when they charge you for new oil when they pull your engine. [img]/ubbthreads/images/graemlins/eek.gif[/img]
2004/03 F350 Lariat 4WD DW CC 6.0 Auto-Trans., 4.10 Limited Slip, Leather Captains Chairs, White over Silver, Heated Seats, Adjustable Pedals, Telescoping Heated Mirrors, Reverse Sensor, Class 5 Hitch. American Fuel Tank/Tool Box 45gal.Lund Sun Visor II, Handy 5th. Wheel Tailgate.
1800 Gold Wing Illusion Blue. Member Of: Blue Knights NJ #1, GWRRA Cycle Clubs, FOP, VFW & NRA Life.
Keystone 5th/W Tail-gator 34ft.
They replaced RMS again & covered under warr. correct? Your warr. has not been voided, correct? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I can see the headaches etc. for you, perhaps your thinking what if it starts leaking again? The info. is in your o.guide book. Maybe this time will be ok. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Good luck...OT
btw...I would imagine by now someone else is asking/wondering why all the RMS replacements. hint..who ever is paying for warr. repairs/seal failures/supplier etc. JMO!
I hear ya. Mines at dealer/svc. today. 1st time. O.leaks, etc. NERVOUS, you betcha. Will start new topic later. RMS gonna be checked out etc. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Driveway sure looks m.t. [img]/ubbthreads/images/graemlins/depressed.gif[/img]
Did they happen to check your glow plug harness o-rings - if they leak it comes out very near the rear main seal and can look like it failed. You can look yourself to see if these are leaking. It where the harness plugs into the block. It will be wet just below and along the ridge .
[img]/ubbthreads/images/graemlins/laugh.gif[/img] 2004 / 04 F350 CC PSD 4x4 Chestnut Brown King Ranch, Quad Captains, DUALLY [img]/ubbthreads/images/graemlins/laugh.gif[/img], long bed, auto, 4:10LS
Goodies added.
Retrax bed cover [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Bed Rug bed liner
KC backup lights
C-Better mirrors
Prodigy Controller
Reese bed rails, bolt on frame install kit
Viair 550C air compressor and 2.5 gal tank
Grover 34 and 36 inch air horns
Pro Flap mud flaps
Autometer cobalt gauges with under cubby pod
Galaxy 95T CB, Wilson 5000 roof mount antenna
DPPI Cat Back Dual Exhaust [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
