Re: location of trans temp sending unit.
From what I remember the pan gasket is reuseable and the trans takes Mircron SP and nothing else. Costs about $4 a quart and I think when you remove the drain plug it drains about 8 quarts.
2003 F250 SC SB 6.0 PSD 4X4 Lariat toreador Red/Arizona Beige, torqshift, 20K miles, engine build date: 1/8/03, truck build date: 1/29/03, all flashes except buzz & inductive, Leer cap, Warn front receiver, Spray-in bedliner, A pilar EGT, Boost & Trans Temp Gauges, high idle mod, CB, 250W oil pan heater with Marinco plug, everything else stock. 4 injectors replaced @ 4500 miles;2 VGT solenoids replaced @ 4500 & 8400 miles; EGR,EBP & MAP replaced @ 12800 miles; 2 turbos replaced @ 13700 & 15400 miles.
