Longer crank time when hot - Diesel Forum - TheDieselStop.com
Old 07-29-2009, 08:57 AM   #1 (permalink)
MickC's Avatar
My 04/04 w/ 100,700 miles is crankin a little longer before starting when hot. Sometimes when it is cold it seems to crank slower. I'm going to take a look with my autoenginuty this weekend. I have service manuals on the way. I'm thinkin a H/P oil leak. Does anyone have the part numbers for the oil seals to the injectors, stand pipe seals, and cap seals. Figure if it is an oil leak, I'm gonna change all of them at one time. I'll check the batteries and for wire chaffing too. Thanks
Also, does anyone have the part number for the air adapter to check for leaks in the oil rails???
MickC is offline
Old 07-31-2009, 07:36 AM   #2 (permalink)
MickC's Avatar
To The Top
MickC is offline
Old 07-31-2009, 01:16 PM   #3 (permalink)
MDKLES5's Avatar
Had same problem, but engine still under the 100K coverage. Dealer claims it was failed o ring and air leak in the ICP valves lower and rear engine. Replaced blown STC and D-rings.
I asked for a layman's explanation, but SA was not familiar with Diesel engines. IF this is any help and you understand it, GREAT!
Just picked up my truck yesterday. Don't know if it worked yet.
2006 F350 6.0 Diesel Crew Cab LB 4x4 Lariat
Hauls 39' Montana 5th Wheel GVWR 14K
MDKLES5 is offline
Old 08-01-2009, 08:32 AM   #4 (permalink)
MickC's Avatar
Yep, makes sence to me. But mine is an 04, don't have the stc. But I have the "D" rings on the stand pipes
04/04 CC Pillar gauges.
MickC is offline
Old 08-02-2009, 05:44 PM   #5 (permalink)
you have the symtoms of a leak in the high pressure oil system. hard or no start while the engine is hot and the oil is thin
halerazor is offline
Old 08-02-2009, 07:05 PM   #6 (permalink)
69cj's Avatar
you might also try disconnecting the gnd. cable at the drivers battery and see if 1 battery voltage increases and the other decreases. Sure sign of a bad battery dragging the system down. If so, replace both batteries. Just had this happen to my 1 year old batteries last week. Good manager at AZ and he replaced both batteries.
69cj is offline
Old 08-03-2009, 08:04 AM   #7 (permalink)
MickC's Avatar
I put autoenginuity on it and data logged. Of course the truck seems to start every time but the battery voltage is dropping to 8-8.5 when I start it. I did put the batterys on a charger for a short period, so I'm thinkin batteries. Gonna have them load tested today at the dealership. Batteries are still under warranty for FREE replacement.
MickC is offline
Old 08-03-2009, 10:12 AM   #8 (permalink)
you need 10.5v for the truck to start
